Evening all
Guest Cob@lt60
Hi guys,
Just thought i would post a message to say hi.. :)
Some of you might know me from the SDU forums.. others wont. :D
I have a swank R32 (Black with blue Pearl), got lots of nice go fast bits on it too..
I'll post some pics of it at some stage.. only got old ones at the moment..
Also if you have any single sisters between the ages of 19-25 im availible.. hehehe
Anyway... Enjoy. ;):lol:
https://www.sau.com.au/forums/topic/3538-evening-all/
Guest Cob@lt60
Yeah, its basically the same since you saw it last..
Got an intercooler and fuel pump on the way..
So.. just the HKS super dragger exhaust, 10psi/14psi (dual stage boost), heavy duty brass button ceramic clutch, cold air intake, HKS SSQV bov. Thats about it..
If only i had an extra 5000 bucks i'd be laughing.. :D Im only aiming for 200rwkw.. otherwise i'll never have any cash.. :)
https://www.sau.com.au/forums/topic/3538-evening-all/#findComment-61279
hhehe I have got a sister!!! but she's taken :)
hey u'll be ok, I'm sure you won't be single for long :D
now hurry up & put up some pics of this swank r32 of yours!!
I've seen it before but I don't think it was with the pearl paint?? can't remember....
Shell :(
https://www.sau.com.au/forums/topic/3538-evening-all/#findComment-61827
Its not to hard to keep up with a 4wd as long as you can launch her properly and have non-low profile tyres on. :D
I kept up with Andy's R33 GTR with a 5000rpm launch. Well should i say i actually was in front :(..
Helped that I had better reaction time also :)
https://www.sau.com.au/forums/topic/3538-evening-all/#findComment-62160
Hey Mark,
They can't find a problem with it. I know it has something to do with when i go into fifth gear my car goes into full time four wheel drive and something is heating up, and causing the lovely burning oil or grease smell through the cabin, then the four wheel drive light comes on. This only happens when i have to spend long periods in fifth at high speed. Can't wait for Mount Gambier, how about you, have you seen the post for the meeting this weekend.
Catcha next time your out cruisin.
https://www.sau.com.au/forums/topic/3538-evening-all/#findComment-65285
Yeah might be the go, Tim has got that bolt-on 500HP R33 turbo pretty much sorted, would love to give it a go. However do not have a spare $2900-$3000.
Should get 250rwkW no probs but for a daily drive is this a bit much? Whatsisname has no traction until third with "only" 236rwkW so it starts to get a bit silly.
Anyway, I'll keep think about it and maybe work out how to get some rear end traction!
I'm sure Tim could do a T3 exhaust flange GT25 for you and make it bolt-on. I'd say a 420HP jobbie would be the best combo for the 2L. It might scare me into buying the GT30 if you get it!!:)
https://www.sau.com.au/forums/topic/3538-evening-all/#findComment-65969
Better quality tyres "should" make a big difference (in my case)
plus the Whiteline rear subframe align/lock kit that's going in on Thursday :uh-huh: Set to "Maximum Traction".
I like being able to over power rear grip at will (in the dry) but sometimes it's a plain ol' pain in the arse. I'd like to have the best of both worlds, kinda' like the GT-R :)
I'm not really making that much power, 300+rwkw is when it gets crazy for a regular street car.
https://www.sau.com.au/forums/topic/3538-evening-all/#findComment-66053
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
