  • Replies 68
well I am a little bored, I pulled apart the spray gun I was going to use and gave it a good clean, ended up getting a good fan from it, but the spray is interrupted every 8-9 seconds though, maybe running too much pressure, today will see me service the hoist jack, can't wait :mellow:.
But there aint much to do until the body parts arrive i have been told that is tuesday.
Hi all,
can't find much on here about it, but I had a look at Enkei's fitment guide and they are saying a 19x10 +35 is best fit for an R34 GTR, I was looking to stuff a 20x10+35 in there, with a 275/30/R20.
Can anyone see a problem with this?
The rolling diameter of my stocks with 265/35R18's RE01's will be just over 3%, so no real matter philosophically there for me, I think the std ratios are a little short anyway. will have copy z-tune guards and lowered adjustable suspension and bushes to reduce cambers and help keep more tyre on the road.
these are the ones I am looking at;
20x10+35 Should fit fine, hell even go a bit lower on the offset I'd say to get it a bit flusher, I'm sure people will agree with me.
First style you posted looks the best, have you looked at CR KAIs or something similar? not sure if they come in 20s but look nice XD9 and XT7 will look nice as well. Then there is the Volk path but $$$$ for GTR sizes TE37s, GT-Cs etc would look tops.
Oh and just FYI - I run 18x10 +15 on my r33 GTR (would have gone bigger but that was the largest they make) and r33 GTR guards are a tiny bit smaller then R34 GTR ones I think. Heres a quick pic of mine:
-Leigh
certainly had the car for a while, must have been one of the first 34 R's in the country back in '02 :)
nice to see it's getting a freshen up :)
It was complied in Victoria too. But generally good to know it has been in Oz for all of that time, makes an estimation of the actual km's traveled a lot easier.
I saw an article of a White R34 GTR v's a GTS Monaro, that was way back when they first came out, always had a sneaky suspicion it was this one :thumbsup:
Would be interesting to know for sure.
Well here it is!
The first unexpected problem >_<
The sump where it joins up with the front diff is cracked.
Darren thinks it was a factory repair that created a weak spot, as the original Nissan silastic was still on the sump.
I did remember the Beer Baron had a 34 sump with a diff fitted, but from chatting with him on Friday, he has disappeared since.
So if anyone out there has a R34 sump with the original diff fitted, I am interested to buy!!
My diff is in good shape, but the cost of fitting and a sump is more than we can get the whole unit second hand. Currently waiting on three people to get back to me from around Australia and the world, so please anyone else, get in touch?
Would like to put this to bed within a week.
First style you posted looks the best, have you looked at CR KAIs or something similar? not sure if they come in 20s but look nice XD9 and XT7 will look nice as well. Then there is the Volk path but $$ for GTR sizes TE37s, GT-Cs etc would look tops.
-Leigh
Thanks Leigh,
Pretty hard to find the Volks in 20's.
Looks like the Enkei's might have to do!
I take it you will be sourcing a set of Xenons for it aswell, instead of the halogen headlights in it now??
Nice build!
Hi Granthem,
It does have Xennon lights currently, but they have been doctored in there, so I found out the other day, the fittings are dubious to say the least!
I guess it wouldn't hurt top put it out there to see if anyone has any Xennon loom clips to solder in from a wrecked vehicle.
UNfortunately the headlights are getting some plastic welding done to them currently. Can't really do too much with the body until they come back.
Definitely be looking for 18x10.5 or more if you want flush. The new TE37SL come in 18x11's. They would do perfectly I think..
Looking to drop the hammer on some of the Enkei GTC01's 20x11+18, they will weigh a tonne, but will put some R compounds on the stocks for track days. They will be dressed in Falken F452 275/30/R20's. the tyres in US are soooo cheap!!
Good price.
Whats wrong with the splitter too? The narrower splitter I believe is designed to work with the Rtune bonnet, which pulls cool air from under the car, past the back of the radiator and out the bonnet vents with the hot radiator exhaust air.
Good price.
That is interesting, I thought the point of the R-Tune bonnet was to pull more air through the FMIC and radiator, could be wrong though. The guards are internally vented to pull hot air from the engine, so that will help the bay stay cooler.
The splitter was too narrow for the bumper, this isn't related to the length, there is a user on here with a top secret splitter available, I have PM'd him, but failing that I will fix the one I have I guess.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
