Xmas specials
- Garrett GT35 Turbo with 0.5 front cover (faster spool then 0.7) and 0.82 rear IW & Custom Braided lines oil restrictor and custom turbo drain etc
Also comes with new 19psi actuator, and hks alloy hard out let elbow to suit. $1700
- Trust Side mount intercooler (uses short piping and goes back into stock piping) $350
- Z32 AFM with plug $200
- SARD 850cc side feed injectors in rail with clips and loom all soldered in $750
- Yellow Jackets coil packs $280 suit r33 series 2
- Apexi Power fc + Apexi Commander with 300kw tune $1300 suit r33
- BLITZ Sbc ID3 SPEC-S Electronic Boost Controller $350
- Nismo 400r Sideskirts suit r33 $200
- Rda slotted rotors & QFM-k750 hight temp pads $400
For sale:
- Nintendo DS Lite, black, brand new unwanted/not needed prize - $100
- HICAS unit, came off a 1998 R33 Series 2 - $50
Also got:
BenQ E2200HD - near new condition - $100
has HDMI input, 22" widescreen, built in speakers etc
Up for sale is my 1995 R33 Series 1.5 Mspec 5sp manual makes 300kw on 18psi
Will make 350rwkw easy with more boost and e85
Price: $19,500 ono
Modifications:
Stock internally rb25det series 2 engine
- Tomei adjustable exhaust cam
- Garrett GT35 Turbo with 0.5 front cover and 0.82 rear IW
- Hpi stainless exhaust manifold
- Metal exhaust gaskets
- Custom Braided lines and turbo drain
- 3.5 "Bell mouth dump front pipe
- 3" Stainless Mandrel Bent Magnaflow cat back exhaust
- 3" Decat
- Silicon Hard intake pipe
- Pod Filter
- Silicon hoses and lines
- Trust FMIC
- Z32 AFM
- SARD 850cc injectors
- Bosch 044 fuel pump
- Exeddy Gtr Cerametallic Clutch Kit
- Lightened Chromolly Fly wheel
- Pro-Stopper Series 5 Alarm
- Triplex Immobilizer
- Head Unit - Eclipise 50x4 CD5444 CD/MS Receiver with MP3/ATRAC3
- Pioneer 6" 4way 280watt fronts
- Kenwood 7x10's 350watts
- Nismo Clear Side indicators
- Kenwood 600w Amplifier
- Kenwood 600 sub
- KYB Coil Overs
- 18" x 9.5 Dtm rush wheels stretched 235's front, 255's rear
- 20% Tinted Windows
- Twin K&N oil breathers
- Water methanol injection
- QFM-k750 hight temp pads
- Custom engineered hicas lock system
post-31991-1259112659_thumb.jpg post-31991-1259112677_thumb.jpg post-31991-1259112687_thumb.jpg post-31991-1259112698_thumb.jpgpost-31991-1259112760_thumb.jpg post-31991-1259112837_thumb.jpg post-31991-1259112876_thumb.jpg
Now 16.5K with stock r33 wheels with semis
r33 series 1 after market front grill (GTR style like the one Talbo was selling a while ago but with the screw tabs)
currently the grill is painted in Wine red
$40 or swap for a standard series 1 grill that is painted black
r33 series 1 coilpacks $120 ono
Danai 0402541975
For sale:
stock r33 dump & front pipe - $30
stock r33 rims and tyres - 2 off - $25 each
r32 seats rear - $250
r32 seats front - $250
r32 gtr gearbox - $500 ono
pickup
gearbox says HXB Nabco japan
pretty heavy tbh, lol. no knees, I could feel it :banana:
Xmas specials
Damn i cant pm yet, but my afm is green and im pretty sure 1993 would be series one
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
