Xmas specials
- Garrett GT35 Turbo with 0.5 front cover (faster spool then 0.7) and 0.82 rear IW & Custom Braided lines oil restrictor and custom turbo drain etc
Also comes with new 19psi actuator, and hks alloy hard out let elbow to suit. $1700
- Trust Side mount intercooler (uses short piping and goes back into stock piping) $350
- Z32 AFM with plug $200
- SARD 850cc side feed injectors in rail with clips and loom all soldered in $750
- Yellow Jackets coil packs $280 suit r33 series 2
- Apexi Power fc + Apexi Commander with 300kw tune $1300 suit r33
- BLITZ Sbc ID3 SPEC-S Electronic Boost Controller $350
- Nismo 400r Sideskirts suit r33 $200
- Rda slotted rotors & QFM-k750 hight temp pads $400
For sale:
- Nintendo DS Lite, black, brand new unwanted/not needed prize - $100
- HICAS unit, came off a 1998 R33 Series 2 - $50
Also got:
BenQ E2200HD - near new condition - $100
has HDMI input, 22" widescreen, built in speakers etc
Up for sale is my 1995 R33 Series 1.5 Mspec 5sp manual makes 300kw on 18psi
Will make 350rwkw easy with more boost and e85
Price: $19,500 ono
Modifications:
Stock internally rb25det series 2 engine
- Tomei adjustable exhaust cam
- Garrett GT35 Turbo with 0.5 front cover and 0.82 rear IW
- Hpi stainless exhaust manifold
- Metal exhaust gaskets
- Custom Braided lines and turbo drain
- 3.5 "Bell mouth dump front pipe
- 3" Stainless Mandrel Bent Magnaflow cat back exhaust
- 3" Decat
- Silicon Hard intake pipe
- Pod Filter
- Silicon hoses and lines
- Trust FMIC
- Z32 AFM
- SARD 850cc injectors
- Bosch 044 fuel pump
- Exeddy Gtr Cerametallic Clutch Kit
- Lightened Chromolly Fly wheel
- Pro-Stopper Series 5 Alarm
- Triplex Immobilizer
- Head Unit - Eclipise 50x4 CD5444 CD/MS Receiver with MP3/ATRAC3
- Pioneer 6" 4way 280watt fronts
- Kenwood 7x10's 350watts
- Nismo Clear Side indicators
- Kenwood 600w Amplifier
- Kenwood 600 sub
- KYB Coil Overs
- 18" x 9.5 Dtm rush wheels stretched 235's front, 255's rear
- 20% Tinted Windows
- Twin K&N oil breathers
- Water methanol injection
- QFM-k750 hight temp pads
- Custom engineered hicas lock system
post-31991-1259112659_thumb.jpg post-31991-1259112677_thumb.jpg post-31991-1259112687_thumb.jpg post-31991-1259112698_thumb.jpgpost-31991-1259112760_thumb.jpg post-31991-1259112837_thumb.jpg post-31991-1259112876_thumb.jpg
Now 16.5K with stock r33 wheels with semis
r33 series 1 after market front grill (GTR style like the one Talbo was selling a while ago but with the screw tabs)
currently the grill is painted in Wine red
$40 or swap for a standard series 1 grill that is painted black
r33 series 1 coilpacks $120 ono
Danai 0402541975
For sale:
stock r33 dump & front pipe - $30
stock r33 rims and tyres - 2 off - $25 each
r32 seats rear - $250
r32 seats front - $250
r32 gtr gearbox - $500 ono
pickup
gearbox says HXB Nabco japan
pretty heavy tbh, lol. no knees, I could feel it :banana:
Xmas specials
Damn i cant pm yet, but my afm is green and im pretty sure 1993 would be series one
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
