need to get the car off defect next week... need cashish so buy my shit haha.
Yokohama AVS lightweight 16x7 +35 all round 5x114.3 with used tyres, still good for skids - $200
r33 rear widebody panels (viva garage ones) brand new, only test fitted rrp $300, i want - $200
http://www.vivagarage.com.au/cart/index.php?c=86&p=81
r33 m-spec front bar, in 2k primer, ready for paint (will be available in a week or so) - $150
r33 aids style s1 bar (burgundy with scratches) - $20
rb25 g-reddy copy intake manifold, brand new (runners straight), will keep if it doesn't sell - $300
r33 automatic tailshaft - $50
r33 standard front pipe + dump pipe - $50
pics:
m-spec bar
s1 bar
Cheers!
still selling my (fake?) AVS model 5's. have been told these are not genuine avs model 5's but im unsure
18x 8 and 9 +38. one front rim has rash and a small dent in it but does not leak. tyres at about 60-70% tread. tyres are 245/45/18.
see pics. $800. ph: 0422603195
can arrange to get them painted if buyer requests. had mine done gloss black for $100 for the set
may swap for some r33 parts
may swap for parts including strut braces, bolt on spacers, foward facing plenum, boost controller, new cooler core that fits behind a reo bar, series 1 reo bar, new centre console, gtr seat + cash depending what you got....
Edited by kenvv
i have an rb25 pod adapter. gasket thing included. $10 pick up add $2 posted
Go fast bits boost t $10 pick up add $2 posted.
King GEE overals size 102r im like 175 180 cm and it fits very bagy on me, but good for rolling round... worn a few times, not needed anymore.
FS: Apexi PowerFC boost controller solenoid.
The boost controller solenoid comes with the solenoid its self, and the wiring with both plugs but on the other side of the plug the 'female' end which would be your wiring that would plug into the standard solenoid thus meaning this apexi boost controller can be made to suit any RB series motor I'll assume being that both ends of the plugs come with this solenoid all thats needed is to chop off your plug in 'your' harness and hard wire into boost controller solenoid.
I've had this for ages with the intention on installing it in my car once I got my PFC installed - Well I sold my PFC and I don't see a point to this hanging around for another 12+months so I'll sell it - Not fussed if it sits there for another 12 months so I'm not really neg on price.
I'll take $150 for it - PM me or contact 0433830055. Should anyone not understand the write up PM me with any questions and I'll clear them up for you asap!
looking like its sold guys :laugh:
No that has nothing to do with this application. The map sensor reads manifold pressure and plugs directly into the top of the pfc with the other loom, without the map sensor the actuator doesn't know how much to open and wont even work
Purchased this last week for JB Hi Fi $39 bux. Watched it once and its not my thing. Will sell for $27. This is a Blu Ray/DVD set. As new condition (because it pretty much is).
Pick up from CBD or Gawler.
pretty sure that's sort of correct any map sensor can be used its just racing the loom i had a boost kit i since bought a AVCR due to it being too hard to get loom and map sensor
didn't want to stuff your sale up but i know you don't want to be known for selling incomplete parts also
FS: R34 gtr wheels
Have been professionally repainted a darker metallic gold/bronze.
Mint condition, not one scratch or mark on them.
They come with Nangkang ns2 tyres, 275/35 with around 80% tread.
After $2200 or R33 gtr rims with decent tyres + 1k.
PM or 0433943034
Brand New Blue Castor Rod Bushes noltec or nolethane to suit R33 sedan or coupe $50
cusco strut bar good condition suit R33 sedan or coupe (front) $130
call me on 0401409575(Allan)
regards
Allan.M
Got my car up for sale, 96 Series 2 R33 with 200atw.
all details are in the following link,
http://www.carsales.com.au/used-cars/priva...920&trecs=1
Haven't changed it on the carsales add yet but will sell without the 19's
Got xr6 turbo 17s on now.
$12900
regards
Allan.M
also a pair of R33 5 stud rims with tyres camber wear on them $60
Hey guys
Selling my panasonic 42'' vierra plasma
Has been in use for only a year, percfect, as new condition. Inc remote and books
Selling only due to upgrade to 50'' full HD plasma
Model number is TH-42PX80A
$550 ono
Pm or 0433073302
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
