For Sale :
RS4 Stagea cargo net. I never use this cargo net, so its up for grabs for quick sale.
Asking $70 pick up. Can post at buyers expense. No promises, no discussion about it. First with cash gets it.
RS4 carbon fibre look centre console plastics
Got CF look panels from auto stick surround up to the air vents (inc ash tray).
Asking $50 plus your plain stock bits to swap. Got to make up something for my manual conversion now, and don't feel like butchering the CF look ones.
PM me.
Tanabe Medalion Exhaust
76mm cat flange to 85mm pipe cat back system. 200mm cannon with 110mm tip to suit R33 GTS-t or GTR, pretty loud but nice note. Comes with slide in silencer. Few scratches on underside of cannon. $300
ARC Super Induction air box to suit R32 GTR.
Brand new, never fitted, complete kit. Retail for close on $1000, $600
HKS/DENSO 550cc top feed injectors
Set of 6. Were in my GTR and ran 322rwkw with no dramas $300
http://injectorsonline.com/indivprod.php?cid=74&scid=12
HKS Reloaded Pods
To suit GTR, good condition, only a few thousand km's old $150
Pics on request
PM or phone/message on 0413697162
Still all for sale
REAL MAN'S SHED FOR SALE
7.4 x 8 x 2.7m (24x26ft)
30deg pitch
5m overall height (enough room for mezanine floor or nice 2 post hoist)
5m roller door with motor
2 x Alu windows
1 x Alu patio door
All colourbond Slate grey
Already dismantled
Located: Surrey Downs SA
$3999
Call or PM 0438 422461
Cheers, Kym
R32 Cusco Type OS front strut brace - $130  SOLD
R32 Gts-t stock turbo, includes dump pipe & actuator - $200
R32 HKS super sound BOV with piping - $40
R32 stock side mount intercooler - $20
R32 stock injectors, set of 6 - one has small crack (yellow ones, check if you need red or yellow) $20  SOLD
R32 rear stock springs, will get you through regency - $20
BRAND NEW R32 centre vent - $70 (retails online for $150)  SOLD
Momo steering wheel with nissan cap, very good condition - $50  SOLD
R32 Skyline and GT badges - $10 all together
R32 Gts-t tyre placard (fits inside glovebox), new, never unpeeled - free + free postage  GONE
R32 roof lining (no pic) - $20
update: most stuff sold, still have stock rb20 turbo, hks bov and some other minor stuff
R32 sedan rear seats and seatbelts, blue, excellent condition - $50
R32 sedan rear wing, grey with led light - $20
Stagea C34 front brake calipers, with pads, seal rebuild kit - $100
HKS adjustable 14psi actuator - $100
r33 front strut brace
also fits r34? jap brand, seems to be lightweight aluminium... $60
R33 gts-t Bridgestone NPG coilovers.
Height Adjustable, Spring rates 8 front 6 rear.
Really nice to drive on, firm but not back braking. just bought a firmer set for track so need these gone. No knocks or leaks. They also use kyb inserts so can be rebuilt in future if need be :yes:
$650
r33 s1 rear seats
$40
r33 30mm widebody front guards
primed in 2k primer, need a bit of sanding then ready for paint
they are viva ones, fit up perfect, all the holes have been drilled in right spots
$250
pm or call 0422 314 938
Edited by SkyHi_33
10" with 235's :yes:
HKS Kansai 550cc top feed injectors
Set of 6. Were in my GTR and ran 322rwkw with no dramas $300 SOLD Pending Payment
HKS Reloaded Pods
Pics on request
Really nice to drive on, firm but not back braking. just bought a firmer set for track so need these gone. No knocks or leaks. They also use kyb inserts so can be rebuilt in future if need be :cool:
$650
r33 s1 rear seats
$40
$250
strut brace goneski. guards and coilovers still available... throw me an offer ;)
Edited by SkyHi_33
give away
R31 Executive Steering wheel
R31 Airbox
R31 panel filter
assorted stickers from a SAAS boss kit
horn button mechanism
6 screws 2 different allan keys
give to anyone who thinks they can use them
ITEMS WILL BE KEPT FOR 1 WEEK BEFORE MAKING THERE HOME IN THE BIN
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
