Hi, Im selling a few things as I dont require them and are just taking up space..
- Nismo 400R rear bar and side skirts to suit R33 GTS-T. Bought from Bodyform in NSW. Have receipt for $945. SELL for $750.
- Also have R33 GTR rear pods to suit 2 Door GTS-T. Have receipt for $150. SELL for $100.
- GTR Fuel Pump from my 1998 R33 GTR Vspec with 60,000kms. In perfect working condition. SELL for $130.
- Trust Air Pods with adapters to suit 32,33,34 GTR. SELL for $180.
- R33 GTR VSpec Air Flow Meters. Excellent Condition. SELL for $260 pair.
- 12" MTX Audio sub with box. SELL $150.
- 12" Sony Xplode sub with box and SANSAI 150W X 4 Amp. SELL $150.
Contact Zak on 0402-137-875.
For sale is my R33 S1 Vented Fibreglass Bonnet & Grill. $400 o.n.o
PM or Phone me on 0413819730.
Local pickup only, located in northern suburbs.
Also have a s2 standard stagea grill $50, s2 stagea passanger side headlight $100 and a R33 s2 stock airbox $50
For Sale
R33 GTST front brake rotors 297mm - $100
RB stock flywheel - $40
RB stock clutch plate and pressure plate $40
Series 2 stagea front calipers $50
RB cas $50
Stagea drivers side glass (very tiny chip in it) $40
genuine Sard FPR with gauge $100
PM me. No time wasters. :blink:
Still for sale
Tanabe Medalion Exhaust
76mm cat flange to 85mm pipe cat back system. 200mm cannon with 110mm tip to suit R33 GTS-t or GTR, pretty loud but nice note. Comes with slide in silencer. Few scratches on underside of cannon. $300
RB25 cam seals
Brand new, part number 13042-16V00AU. Retail for around $16 each, asking $20 for both.
PM or message/call 0413 697 162
have a bunch of r33 brake/suspension bits left over from the conversion i did on the silvia;
hubs
control arms
maybe lca's
probably a few other bits too. If your after something let me know, pretty much what i used was calipers, rotors and rear hubs. Think the rest should be there.
Selling my Drift Teks, Gold 18x8.5 +34 4/5 stud $1000ono come with a set of Hancook's 225/40 (i think) not fitted, will chuck pics of tyres when i get time.
hey mate where to in adelaide are u?? wanna have a look at the rims.. are they in good condition?? also what condition the tyres in?? pm me your mobile number easyer to talk with msgs cheers
For sale:
R32 GTR standard aluminum bonnet and grille - $200 for both - both in gunmetal grey - grille has some broken clips - bonnet has very minor damage at the very tip - could make a cheap lightweight track bonnet for GTS-t owners or can be fixed by a panel beater
For sale:
Any chance of pics to PM on this vu?
1979 SA RX7 Green Metallic
13b with 37,9xx km's
Manual
would be registered as a classic
had a 12a engine in it before and was roughly driven for 13-14 years with 10-20000,kms a year
so really the 12a would be for parts etc
has abit of rust on back bumper, top of right door, back wheel arch
2.5 cash
Edited by Pepsinator
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
