Running out of time to pay for parts on hold so...
I have
2x Stanton T.60 vinyl decks with cords and slipmats (got them 2nd hand off ebay 6 months ago)
2x Ortofon Om Pro S scratch/mix cartridges with new Stanton Headshells (brand new 6 months ago)
1x Audioline 4ch mixer (dmix4sp) with cords (brand new 6 months ago)
10x jungle/drumn'bass vinyl
old pair of headphones
record cleaner
old cartridge and headshell 1x
All items in good condition only used the setup a dozen times and is now in boxes under a spare bed
All you will need is an amp and speakers, I had it hooked up to my surround sound
$580 ono
More info and pics on request
Regretful sale, help fund my mods!
1-Set of 3 piece jap meshies
Front 17x9+29 with Yokohama c drives 215 45 17 approx 90%
Rears 17x9.5_22 with Khumo platnium 225 45 17 approx 90%
Bit of rash being 2nd hand rims nothing major
Will need spacers to clear front gtst brakes
$1300 ono
2-Genuine Red Rays lock nuts packet of 20
Never used the nuts just opened the packet to use the lock key
Nissan thread 1.25
Still have the reciept from JIS
$180 ONO
3-150mm pink dildo shifter with nissan/toyota thread
$40 ono
Contact via pm
Edited by mark ii
r33 gtst sr1 carbon bonnet bought from autobarn paid $1300 a few years back only used on my car for a few months just been sitting in my shed. has a few light scratches $500 ono
R33 gtr spoiler needs a rub back and paint no end caps $250
R33 4door front lights $250
HKS 25/35 turbo kit (direct bolt up to rb20, 25 and neo 25... uses stock dump, mani etc etc..) i have had braided water in and out made, stock oil in and dump. the turbo is 15,000ks old from new and is in IMMACULATE condition. $1600 FIRM with lines
tein type CS coilovers
suit auto rs4 stagea (series 1 and 2)
32 wat dampner adj, heigh adj
comes with c spaners, some stickers from new, and the little dampner key.
also will include 10k old isc toe and camber arms
$850
sold the pair of z32 air flow metres. one delivered, one on hold pending 3 enquiries...
so all up for sale I have:
1x pair stock R32 RB26 GTR manifolds $100 the pair
1x pair stock R32 Rb26 GTR turbo dump pipes $100 the pair.
1x 5-point clip-buckle harness, brand RCI. $50
1x r32 rb26 GTR oil pump, used but in good condition $50
1x r32 RB26 GTR harmonic balancer, in good condition (used) $80
1x oil catch can with mini pod-filter, brand new, $50
1x 3-guage holder set, new. $30
2x Q45 Air Flow Metres, Working condition, with plugs. $100 the pair, or $50 each
1x pair pod filters. Brand new never used. $50 the pair, or $30 each seperately
1x stock R32 RB26 GTR Intake pipwork, $50 the lot
1x stock R32 RB26 GTR coilpack cover blue, $100
1 x stock R32 RB26 GTR turbo two-into-one exhaust front pipe, good condition $50
1x 3" decat pipe with flex section, brand new never used $60
1x 3" twin barrel mid-muffler resonator section, brand new never used $80
1x full set Tein suspension to suit R32 GTS-T. Came out of four-door R32. Tein shocks/springs. In good condition $500
thanks. PM me and we'll arrange what you want, etc.
cheers
Brendan
hey mate interested in the suspention! is it lowered spring or just standard?
$850
hey mate really interested in the coilovers! would like to see some pics! let us know! cheers
1: R32 "A" Piller mounted boost guage trim to suit 60mm guage $30ono
2: HKS Boost guage and loom (60mm) $50ono
Or take both for $70
Not sure what they are exactly worth. Sorry the pictures arn't very good, they were taken with my phone.
Come come people, I need these items gone asap. The boost guage will not come with the vaccum hose due to me using it for another boost guage.
RB25 850cc top feed injector kit
Been test fitted, never used. Some cosmetic damage (few scratches) from test fitting etc. but doesn't affect the operation at all. Doesn't fit standard manifold hence the reason I'm selling them.
Suit rb25 with aftermarket manifold. WILL NOT FIT STANDARD MANIFOLD.
Comes with
6x 850cc Siemens DEKA injectors
fuel rail
all fittings
all o-rings
all harness plugs
Its all there ready to bolt on.
$600
pm or call 0422 314 938
Edited by SkyHi_33
    • Threads merged. Only need one for the same question.
    • Hi everyone, I'm about to complete my first single turbo conversion on my R32 GTR and I thought I would post the step by steps that I will be following. I will list the parts I have / the parts I will be buying. I will be redoing this guide after I have completed the conversion. Parts list: - 3576 turbo 0.82 v-band (coolant and oil)  - v-band top mount turbo manifold - 50mm wastegate - manifold copper gasket - titanium manifold stud kit - turbosmart 3 port boost solenoid - link can lambda kit (wideband) - link ECU - radium 12AN push in valve cover fittings (pair) - hi octane catch can - 3.5inch downpipe - screamer pipe - pipe from turbo to intercooler - intake pipe setup - power steering relocation kit - oil drain block off plate - coolant and oil lines Now onto the step by step guide (please add / correct me if there's anything I missed: 1. remove fluids, twin turbo pipes, pod filters and afm's 2. remove the factory coolant hardlines from the hot side. 3. remove heat shields  4. remove the downpipe 5. remove turbos and manifolds 6. remove factory manifold studs 7. clean whatever mess you have made 8. install power steering relocation kit 9. install new manifold studs 10. install new turbo manifold with gasket 11. install new wastegate with screamer pipe 12. install new turbo  13. install new coolant and oil lines  14. install rear oil drain block off plate 15. stop and appreciate that you now have a single turbo in your GTR 16. wipe away tears of joy and install downpipe 17. install the wideband sensor into downpipe 18.install pipe to connect turbo to intercooler 19 .remove stock boost solenoid  20. install new boost solenoid 21.  install intake setup 22. setup the rest of the can lambda kit with the ecu  23. refill fluids and hope for the best 24. ask forums for help with issues 25. fix issues 26. drive your single turbo swapped r32 GTR into the sunset. Doneeeeeeeeeee. Now I know this isn't detailed at all but I will be doing that when the conversion is done. I will be posting pics and any helpful details i can and ill make sure to fit in as much information as I can. If there's anything I should know before i do this PLEASE let me know. Stay tuned for what's next. Thanks...
    • I have wasted too much time on this, more than I am willing to admit. I hope someone can set the record straight for me.  I want to replace my Nismo (non GT pro, non GT) standard 2 way in my R33 GTST with a 1.5 way... Ideally I want to get an ATS 1.5 way Carbon LSD, but I don't want to reuse my 29 spline 5x1 axle stubs, and new 30 spline 5x1's are impossible to get a hold of ($$$), and I don't want to drop the cash on going to 6x1 stubs and axles ATM. Which leads me to the Nismo GT Pro 38420-RSS15-B5 or RSS20, as they come with new axle stubs meant for the diff, and is "Convertible" from a 2 way or 1.5 way to "Other ways", but that is where I am stuck as the documentation is a bit all over the place.  To sum up what I have found I believe the all the Nismo GT Pro PN's are convertible from 2 way, 1.5 way, and 1 way; but Nismo sells 2 skus (2 & 1.5) so people do not have to disassemble to convert it.  I found this thread on 350z but it left the question unanswered. https://my350z.com/forum/engine-and-drivetrain/620032-nismo-gt-pro-lsd-1-5-vs-2-way-and-torque.html  Essentially the way I think it all works out is like follows...  2 way  1 way  and 1.5 way would be the center pinion shaft in the 1 way block, but with the with the center flipped 180*. So the ramped side of the pinion would face the 1 way gate and act like a ramp.    I can only get my hands on the 2 way in the states, and I am not trying to get stuffed on tariffs by ordering from Japan or anywhere else. I want to confirm that if I get the 2 way I can convert it to the 1.5.
    • Hi everyone, I have purchased my first GTR and I want to do a single turbo conversion to it. I've been doing as much research as i can and there are a few things that I can find and need to know. I need to run a coolant feed, coolant return, oil feed and oil return for my turbo setup. Here's what I know so far: On the hot side of the rb26 there is coolant feed, oil feed and oil return. Coolant return will be going around the front of the engine to where the thermostat is located. I will need to block off the rear oil return port. I will be running a turbosmart boost solenoid so any of the factory boost stuff wont be needed. Now onto what I don't know: 1. What do I do with the coolant / vacuum hardlines that run around the back of the motor?. 2. What do I block off or loop or move or remove?. I will be running the OEM intake manifold. 3. Is there anything in particular I need to buy for the cold side of the rb26?. I already have the intercooler and pipes sorted. If you have any pictures or information it would be appreciated. Thanks....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
