Hi guys
Greddy 3.5" catback to twin 3" straight pipes from diff back. All Stainless Steel with hangers and rubbers to fit r33 gtst or gtr - $380
q45 AFM with plug, good for big power applications - $100
pm or call 0422 314 938
pics:
http://i2.photobucket.com/albums/y33/kfsRule_2/IMG_3516.jpg
http://i2.photobucket.com/albums/y33/kfsRule_2/2011-01-23173743.jpg
http://i2.photobucket.com/albums/y33/kfsRule_2/2011-01-23174036.jpg
exhaust sold :)
got a RHS electric window winder up for sale got it for 185$ yestaday but dont need it as the one on my car was just lose :domokun:
price $ 150 $
also got a fule lid with dent in it $ 5 ono
Need to sell the folowing parts, all parts cost me a lot more than what I am selling for, need cash however I can get it to help pay for engine rebuild:
mid-pipe, 3" inch, flex pipe section - to be used instead of your cat-converter
$50 pickup, brand new
3" inch entry/exit, twin barrel resonator muffler system
R32 GTR two-into-one front pipe, R32 GTR turbo dump pipes, R32 GTR twin turbo manifolds
$80 pickp for the exhaust parts, in excellent condition.
Jason Ezyboy recliner chair
To suit granny or children; not full sized!
In excellent condition, need it gone before I move house shortly
$40 bargain!!!
Pickup from Morphett Vale 5162; all items must go!
R32 sale of the century!!!! Haha
I have a 4 door I want to turn to stock that's been set up for drift fortunately I like real driving what involves handling lol. So I have a list of parts I want to get rid of that I would either swap for the stock equivalent so u can gain a crazy good part for ur stock one or make an offer on the stuff I have.
First up I have a r32 GTR diff that has been shimed that I want to swap for a stock 4 door diff no money wanted for It straight swap!!
Second I have the annadized blue alloy pineapple mounts in the rear what I would take an offer on or swap for a working set of rubber mounts!!
Thirdly I have a blitz nur spec stainless still exhaust with a broken mount that is an easy fix I wanna just get rid of ad would swap for a standard front dump pipe for a 32 or just an offer.
And lastly a rear d1 style bumper that's white that I'll swap for rear pods or just an offer.
So if anyone is keen msg me on 0433370776 or pm me. Msgin on my phone will get u a much faster response as I'm not on here often.
R34 gt-t stock wheels.. 17x7.5+40 with no tyres I'n average condition $250
15mm spacers with all studs . Suit nissan 5 stud $80
Stock r33 cooler and all pipes $60
Or
$350 the lot
Pm or text 0431528958
Edited by joeyy
PRICE DROP ON SOME ITEMS
RB25det sump $30
R33 sr2 wing needs paint $30
GTR wing no end caps needs painting $150
R33 Air Conditioning Condenser gtst 1994 $35
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 climate control $35
R33 gtst fuse box and cover $20
R33 gtst sr1 bonnet hinge set $15
R33 gtst overflow and washer bottle $25 for both
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50
R33 gtst battery tray need painting $10
RB25 R33 GTST SR1 CAS CAM ANGLE SENSOR AND BRACKET $45
R33 clutch master cylinder $30
R33 RB25 skyline power steering reservoir with lines $20
RB25det fuel rail $20
RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20
R33 Air Conditioner Compressor with lines as seen in pic $55
RB25det sr1 aac valve $40
r33 gtst sr1 carbon bonnet $400
fiberglass vent (uncut vent) $50
rb25 turbo 45v2 has a blown seal $50
R33 gtst sr1 abs unit and bracket $60
Rb25det sr1 flywheel $40
R33 gtst coupe sr1 door handle's $30
R31 sr3 grill $10
R31 sr3 bits lot $15
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25
R33 gtst light garnish $30
R33 centre interior light plus other? $25
R33 turbo oil drain pipe $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $90
r33 horns $10
r33 sr1 bonnet in primer has a few scratches and a small dint from sitting in the shed $120
catco high flow cat 2.5inch 325mm long $50
apex rb25 front pipe 2.5inch has a few dings $70
Nismo muffler 2.75mm inlet with 4.5inch tip $130 plus rear section that suits r33 free with muffler
RB hard oil turbo line $25 (not sure if its rb20 or rb25)
RB hard water turbo line 1 $25 rb20 rb25?
RB turbo hard water line 2 $25 rb20 rb25?
R33 gtst window wiper set $ 15
R33 gtst sr1 electric driver side window switch and loom $50
R33 gtst sr1 passenger side electric window switch and loom $45
R33 gtst sr1 2door seat belts(not sure if its complete) $50
RB25 clear timming belt cover(never used)$60
PICS http://www.skylinesaustralia.com/forums/topic/364044-shed-clean-out/page__p__5808980#entry5808980
pm me or 0435888239
Will post at buyers expense
Dave
180sx ca18det manual unfinished project
Imported engine with 5sp gear box has been told 60k miles.
Full body kit, s14 turbo, after market exhaust, 17" wheels, performance coil spark, leather seats, GAB shock, new brake pads and much more…
Car has been sitting around for 2 years and some interior/exterior bits tripped out but i have all parts.
Car has SA defected on it so selling as is for parts, track/drift.
$3000 ono, text me on 0430606223 steven
for you S chassis drifters
Ive got a complete package for those with an S14/15 (or s13 if you have 5 stud hubs). Bolt in, wheel align away and improve your lock, reduce the ackerman and increase steering responce! These are a proven design, as used by myself, Christian Pickering, Luke Broadbent and various other drifters around australia!
Knuckles are cut, professionally Tig Welded into the correct positions after careful testing, they are then braced for added strength. you will not break one! (unless you smash your car but chances are you'll have other things to worry about then lol) in saying that these are not road legal so use them at your own risk.
Bolt on rack spacers are designed to give 20mm additional travel along with spacing your tie rods out to take in account of the reduced knuckle ackerman, they also reduce any binding. CNC machined and chemically blackened.
last pair i have!
Price: $500 + postage
contact me via PM
Pics!
Up for sale is my 1995 R33 Series 1.5 Mspec 5sp manual
Car makes 260rwkw on only 15psi, has the following mods:
Rb25det Series 2 engine
· 3" Stainless Mandrel Bent Magnaflow cat back exhaust
· 3" Dump front pipe
· 3" hi flow cat
· Twin 2.5” Stainless rolled tips
· Pod Filter
· Silicon hoses and lines
· Bosch 044 fuel pump
· Exeddy Gtr Cerametallic Clutch Kit
· Lightened Chromolly Fly wheel
· Pro-Stopper Series 5 Alarm
· Triplex Immobilizer
· Head Unit –Pioneer 50x4 DEHP5150USB CD/MS Receiver with MP3/ATRAC3 USB
· Pioneer 6" 4way 280watt fronts
· Kenwood 7x10's 350watts
· Nismo 400r Sideskirts
· Nismo Clear Side indicators
· Kenwood 600w Amplifier
· KYB Coil Overs
· 20% Tinted Windows
· Twin K&N oil breathers with fliters
· Custom engineered hicas lock system
· Nolathane bushes
· Z32 Air Flow Meter
· New Frount Mount intercooler
· New High flow turbo (Rb25det turbo 21U Hypergear highflow gt3076 core)
· New Remaped ECU
· Manual Boost controller
· 18x9" ROH Drift R wheels with near newYokohama Advan Semi slick 235/40/18 all round!
post-31991-0-65905000-1309828262_thumb.jpgpost-31991-0-25592500-1309828294_thumb.jpgpost-31991-0-60952700-1309828370_thumb.jpgpost-31991-0-56840200-1309828412_thumb.jpg
Is capable of 285-300rwkw with more boost, see attached dyno charts, car is stealth under the bonnet as to not attract the wrong sort of attention.
Very fast street car not for the faint hearted, would do excellent track / quater mile times too. Great for street daily driving or tracking when you want to have some fun
Car starts first time every time, is in excellent condition as per pics, reason for sale is have purchased a track car.
Note wheels not included(avaliable for purchase), will come stock r33 ones
13k
Pm with enquires
Final price drop 12k
Will strip parts if not sold soon (pm me with interest)
hey guys here some stuff for sale from my R33
window wipers for front and back $30
nissan skyline R33 floor mats no front mat's only back mat's $30
R33 boot carpet to hide back lights $10
Monza mspec seats $400
R33 back light lift side cover $10
Intercooler kit is straight "plug in and go.. and no there anything u need to modify to get the cooler to fit.. yes the
cooler work.. and no cracks in the pipes or cooler..
yes it come with mounting brackets and all u need 2 get it runing $350 that with free post any in AUS
rims off my skyline R33 GTST 5 stud now front wheels will only fit with wheelspacers only.. now back wheels fit with out wheelspacers they look good on the car get lots of looks and asking where i got them from but i do not know what they are because they came with the car
front are 235/45/R17 rear are 255/40/R17 nice dish 2 them as well they look nice...sell for $500 no tyres.will post.. thanks
post-81807-0-92267800-1306455025_thumb.jpgpost-81807-0-68861300-1309953284_thumb.jpgpost-81807-0-60920600-1309953269_thumb.jpgpost-81807-0-20357300-1300065778_thumb.jpgpost-81807-0-15270200-1299195082_thumb.jpgpost-81807-0-48924500-1299194862_thumb.jpg
post-81807-0-96838000-1299553489_thumb.jpgpost-81807-0-83329900-1299553472_thumb.jpgpost-81807-0-29807500-1300065552_thumb.jpgpost-81807-0-64623800-1300065435_thumb.jpg
Hi guys. Thinking about selling my Nissan Stagea to get a 4wd with a larger towing capacity. I will consider SWAPS for a 4wd, after a dual cab as a minimum so dont tell me about your utes or commodores/falcons. Or a Cash sale
  • -Nissan Series 2 RS4 Stagea - Snow Edition with lockable centre diff
  • -Tiptronic auto
  • -140K kms
  • -Neo Rb25det, had factory nissan 100K service done by Nissan. all new belts, pumps etc etc, very well looked after and maintained
  • -Bleed valve and boost gauge, running 11psi. goes very well
  • -D&T exhaust system - have reciepts
  • -Tow bar fitted. have towed my race car + trailer + full car of people + fuel and tools + tyre rack with no drama's does it very well
  • -Tein Wagon Master coilovers. near new, have the reciepts, manuals and adjusters for them. handles great!
  • -18inch Speedy wheels all round with Federal 595's up front and neutons on the rear. plenty tread left
  • -3 months rego
  • -Pioneer MP3 player with a full set of awesome speakers/splits. sounds great without being over the top
  • -ALL electrics work
  • -inside and outside is immacualte!
  • -Recently fitted a triple point alarm/immob which complies with Aust standards and insurance worth $700
  • -have a stack of reciepts for the various work done
Price - $12,000firm or swaps as above in bold.
Pm me or call/sms me for info. 0412 938 933
Some pics.
Nismo Lm gt4 bronze wheels 17in x 8.5jj + 30 an 17in x 9.5jj + 38 rims
Great condition with potenza re001 225 an 255 tires that are near new
Great track rims forged monoblock an weigh 7.7kgs!!
Perfect for r33!!! Also r32, silvia etc
Price $2200
Rear tyres low,
Price drop $1900
Price Drop
All items Brand New, never used or fitted -
2 x Garrett GT2860R -5 Turbos $ 2000
18 x M8 x 1.25 Turbo Studs and Nuts for Garret Turbos $ 50
1 x Set of ARP Exhaust Manifold Studs, Nuts and Washers for RB26DETT $ 130
1 x Genuine Nissan OEM Complete Engine Gasket Kit Set for RB26DETT R34 $ 170
Or the lot for $ 2300
In Adelaide ready for pick up.
I will post anywhere at buyers expense.
Call me on - 0401469148
hey all, sadly my r33 s1 gts is up for sale and need to see her go due to my upgrade to a gts-t
its got 213xxxk's from when i checked last, has alarm, 18 inch rims, lowered, nice stereo with 2 12x subwoofers, window tint all round, all electrics work, immaculate interior and pree decent engine bay, black in colour.
need it gone for $6990 slightly negotiable, doesnt have rego atm.
any Q's ask
carsales link: http://www.carsales....words=&__N=1216 1246 1247 1252 1282 4294963846 4294963593 443 901&silo=1011&PriceTo=443&seot=1&tsrc=allcarhome&__Nne=15&trecs=14&__sid=130AA1DA7BD3
call me on 0422360999 or send me a pm
cheers aaron.
Edited by buzz350
tem 1: Genuine NISSAN Weather shields to suit R32 2 door (possibly 4 door??) Driver's side is perfect but the passenger side has snapped about 3/4 the way up over the window. So you're essentially buying the driver's side with a free 3/4 passenger side, get my drift???
PRICE: $70 for the 2
Item 2: Passenger and centre air con vents, replace your broken vents!
Price $140 for the 2
Item 3: Upper control arm bushes for your 32, stock with nolathane bushes. Help u get through Regency
Price: $60 considering its cost $90 for just the bushes new!
Item 4: 2 x ignition barrels, steering column with keys
Price $100 each
Item 5: Jap front strut brace, look like Cusco??
Price $60
Item 6: Drivers and passenger side complete doors even with speakers!
Price: $100 each
Item 7: Stock 32 4 Door rear bar in silver
Price: $50
Contact via PM or 0425008999
Aight guys got another toy for sale:
R32 4 door type 1 rear bar. Perfect nick in white. So primered ready to go. I'll take 75 bucks. Or a standard bar as swaps. It retails for 250 so get a deal on a perfect clean example!! Pm or call 0433370776
R32 4door RB20DET - $6000 must go as I have a loan set up to head over seas.
bigger turbo
ford typhoon intercooler
genuine MINES ecu
18" wheels
nismo adjustable castor rods
3" HKS exhaust, pioneer dvd player
brand new 6 1/2 splits in front doors
sub and amp in boot
Bodykit in good condition except front bar has couple of cracks, rear bar not installed and neither is flaired guards.
wingless boot
PLUS R33 GTR cooler, standard turbo and ecu and other parts.
Edited by Minibats
Clear Indicators of my stagea also suits ???? no rubber backing or wire loom included: $35
Single din nissan pocket: free to anyone who might need it
Mates Drift 52mm oil gauge
Used, Multi colour, pressure sensor included: $65 ono
Type 1 Turbosmart BOV
vent to air and attract the cops: whats it worth to ya?
All pick up
sms 0430 613 360
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
