FOR SALE:
WHEELS NOW SOLD!!
NEW unused carbon fiber vented bonnet r33 gtst series 2.. bought it for $800 now selling for $600
R33%20GTS-T%20VENTED%20CARBON%20FIBRE%20BONNET%20BODY%20KIT%20AERO%20KIT%20AERO%20.JPG
Also got used genuine front left side control arm and also left hand side caster radius rod bracket selling due to lack of knowledge in some of adelaide's work shops.. both for $100 or $50 each.. (pics for this 2 parts on request)
located near Salisbury
Txt me anytime for any question 0415440332 cheers :)
Momo Race wheel & boss kit in good condition (to suit r32's, was on a gtr)
$150.00
Apexi Pod filters & brackets to suit R32 GTR in good condition
$150.00
6 x Standard RB26 444cc injectors, removed to upgrade
$180.00 SOLD
Located at Victor Harbor,
PM on here or sms / call 0415 117 115.
Rob
Big thick Cusco rear S13 strut Brace $100 firm
R33 GTR grill White mint condition $200
Sr S13 turbo front brand new rotors $100
Clear 180sx lights ( never seen another set same in S.A ) $200
r33 white fibreglass grill $100
r33 eyelids $50
Fuel setup , bosch 910, swirl an holder all new $300ono
r33 tailights, surrounds black $50
r32 4door skirts an pods brand new genuine nissan plastic $600 set
Text on 0407 627 431 Located South of Adelaide
Hypergear TR43, Unknown km, came out of my 1999 R34 GTT with no issues at all with it, no shaft play, no smoke, bolts straight on, comes with V band and dump, oil line (everything in the picture). - $700
Turbo Information
R34 GTT Stock ecu Auto - $150 - Sold
R34 GTT Stock Injectors x6 (Part number: FBJE100) - $100
RB25 Rocker Covers (Crinkle Black) - $60
Manual Boost Controller (think its an atomic boost controller) - $50
Turbo sold pending payment.
Hi guys got a defected 1993 R32 gtst manual
-120000 on the odometer
This car will make a great summer car,all it needs is stock suspension and silencer for the exhaust..
Its got Vertex body kit
-Fiberglass bonnet
-Wide rear
-Tein coilovers
-Front mount intercooler
-Very clean interior
-17x8 ENKEI wheels with good tires on
-Not boosted
Price is $3400
For more info call/txt on 0421072135
in case i don't answer,ill get back to you as soon as i can.
Edited by SAKS
Greddy Profec b spec 2
second hand but works perfectly. Comes with everything you need. holds stable boost without an issue. only selling due to upgrading ECU which has boost control function.
pic so you know which type
Price $300 posted.
Neo R34 Nistune ECU
Ecu is plug and play in any manual R34 or stagea with neo motor. has nistune board on it ready to go. Also has tune for e85, cams, 3076, injectors, z32 but thats useless to most people. your buying the ecu here pretty much.
Price: $600 posted
R32 GTR Radiator + Shroud
near new R32 GTR radiator from Koyo (only 3 months old) inside of core is as new condition, outside is a little muddy and dirty but will clean up no worries. With shroud which is not cracked.
Price: $300
RB clutch fan and Hub
RB30e hub (shortest of all RB hubs) and R34 neo fan, useful for running clutch fan in your RB powered S chassis
Price: $120 posted
Intercooler
300x450x76mm with 2.5inch in and outlets. ideal for mounting in tight spots. 6 months old and inside of core is spotless and oil free. minimal bent fins
Price $100
Z32 AFM with plug and Neo plenum pipe
pipe is made to relocate the AFM on the cold side of the intercooler before the throttlebody. pipe also eliminates the over the radiator location. can be adapted to fit any neo enginebay. and probably any RB engine. AFM is 12 months old comes with plug and works perfectly.
Price: $400 posted
Located Adelaide SA. can post any item
contact details.
PM me or txt 0412 938 933
-Fiberglass bonnet
-Wide rear
-Tein coilovers
-Not boosted
Price is $3400
SOLD SOLD SOLD
RB25det sump $30
R33 sr2 wing needs paint $30
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 bonnet hinge set $15
R33 RB25 skyline power steering reservoir with lines $20
RB25det sr1 aac valve $40
fiberglass vent (uncut vent) $50
R33 gtst sr1 abs unit and bracket $60
Rb25det sr1 flywheel $40
R33 gtst coupe sr1 door handle's $30
R31 sr3 grill $10
R31 sr3 bits lot $15
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25
R33 gtst light garnish $30
R33 centre interior light plus other? $25
R33 turbo oil drain pipe $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70
r33 horns $10
Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler
RB hard oil turbo line $25 (not sure if its rb20 or rb25)
RB hard water turbo line 1 $25 rb20 rb25?
RB turbo hard water line 2 $25 rb20 rb25?
R33 gtst window wiper set $ 15
R33 gtst sr1 passenger side electric window switch and loom $45
R33 gtst sr1 2door seat belts complete $50
R33 gtst sr1 air con units that sit behind the dash, heater cores $90
RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20
vr v6 commodore sedan fuel sender and pump(pulled from running) $40
r33 boot latch with plug $20
R33 boot and fuel lever $15
R31 1989 oz spec bonnet latch and lever $10
R33 a/c receiver,drier sensor $30
rb25det fuel modulator with bracket$25
R33 rear window $40
R33 stereo brackets $20
R33 sr1 dash trim(needs a clean and paint) $40
R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25
r33 sr1 bonnet in primer$100 has a small dent(can send pics)
R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $40
R33 gtst false rear wall $20
RB25det stock dump on black vht $20
R33 gtst rear bar, will need small repair $25
r33 gtst sr1 power window motor regulator passenger side $70
R33 gtst rb25det hicas computer $50
R33 bonnet in black primer has a small bend in lip $50( can get pic)
R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $20
Rb25det sr1 cas with bracket $50
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50
I have r33 interiour parts, pm for what you after
pm me or sms 0435 888 239
Will post at buyers expense
Dave
R34 GTT interior/exterior parts for sale
rear boot light:$30
door trims: missing some things but either than that its in good condition: $80
parcel shelf: $40
Rear reverse lights: $30
standard oil cooler: $40
standard intake pipe: $60
rear quarter interior trims
$100
$40
R32 gts-4 complete minus engine bay and trans has gtr interior trims and recaro style front seats has sa plates $2800
I got complete R33 GTS4 series 2 running gear that sum1 could use in this car. (5 speed rb25de - ALL parts needed are there).
Hey all
Maybe moving interstate shortly so i thought id pop the hilux up for sale
Ford blueprint blue respray,less than 12months old
Rays progressiv2 rims meshies
Fronts 17x8+6
rears 17x9+13
awesome wheels and might keep them if i dont get a decent offer
Professionally lowered with pedders shocks and springs all round
C34 laurel leather and electric front seats.pimp
Tubs been shaved
4wd front gaurds and chrome grille,apron etc
Motors been rebuilt by previous owner,done about 20thousand k's since
Recently did oils,filter and brand new belts
Chassis' done over 300thousand k's but all bushes etc have been replaced
5 speed,loves to sit on 110kph on the freeway
Open to swaps for something cool,would love a 4door r32 but will look at most offers
Decent stereo with fronts in the doors,6x9s in the rear run off a sony amp,mp3 head etc
Or $8000
Slightly Less without wheels
Motorbike tie down points in the tray
Rego as a 4 seater,all belts ect in the back
Cant upload pics atm,but if anyones keen ill mms pics to them
0421754575-rodney
i have a blown RB25DET awd sump that suits a rebuild ;) R32 with awd turbo 25 would be great
Quite negotiable on the price Just need it gorne to get some cash for The D-car.So someone must want a clean car paint needs work but still clean enuf for street or can do cheaper striped So Buy my gts-4
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
