ase oil cooler core
speedflow/aero flow fittings
relocator
sandwitch plate
lines
to fit r32 behind grill or anything else if you make new brakets/lines
$400
defi BF guages.
oil temp
water temp
oil pressure
+ all sensors and control box
black with white light.
$650
Nismo 550cc yellow injectors for r33 rb25. were cleaned, flow tested and new o rings fitted when they were installed in June this year. only being sold as ive gone bigger, perfect condition
$650
Josh
ps, currently still in the car will be removed in the next week
Massive Price Drop for Christmas
Need the Guards, skirts and boot trim gone ASAP as parents are complaining about room in the shed
For Sale R32 bits from a 2 Door
. R32 - Vented Fibregalss Front Guards in Gunmetal Grey. In pretty good condition. RH Guard has part of a Fibreglass GTR N1 kit on it and is sikaflexed on. $200 - $100ono for the pair.
. R32 2 Door - Fibreglass Side Skirts In Gunmetal Grey. Not the best condition. RH skirt is GTR N1 Style & LH Skirt is Type M. $50 - $20ono for the pair.
. R32 GTST - Front Indicators painted but look awsome on a dark color car. $60 - $30ono
. R32 GTST 2 Door - LH & RH boot Trim. $10 - $5
Or take the lot for $150. Feel free to come and have a look at the parts.
Price drop need these gone ASAP, need the $$$
Also for sale is a
. Garrett 2530 with HKS .64 Exhaust housing. Turbo came off my rb20det, unsure of Km's on the turbo.
Turbo came off my rb20, was making 184.4rwkw on 12 or 14psi can't remember exactly
Turbo does not come with compressor housing, oil or water lines but comes with a Stock rb25 actuator.
I'm no expert on turbos but I suspect the shaft has more than usual freeplay. Turbo does not blow any smoke.
Some slight damage to compressor wheel
Feel free to inspect the turbo and see what you think.
Unsure of what the turbo is worth so i'll say $380 - $280ono
. Greedy Adjustable BOV with RB adaptor plate and gasket between bov and plate $60ono
Located southern suburbs but I work in Wayville so I can bring parts to work for you to look at. PM or txt for further info 0433 522 234
Pick Up only but am willing to meet you somewhere
Pics for body parts and turbo are on Page 365 in Post 7283
Cheers Tim
FOR SALE
R34 GTR V-Spec FMIC
R34 GTR V-Spec Cams and Cam Gears
R34 GTR V-Spec Radiator
S13/14/180 Roll Center Adjustment Bar
Make an offer on this stuff, just sitting in my garage... Haha
0408878086 or Pm me...
Cheers, Brad
Set of stitch evolution wheels, theyre 5x114.3 17x8 +8 offset all round
Bit of gutter rash on two wheels, nothing serious. No buckles, no cracks etc. 2 good Dunlops up front, rears goneski.
$600 ono, need em gone!!! taking up too much room
on car with no spacers:
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=370161
pm or 0422 314 938
Edited by SkyHi_33
5x R33/s14 stockies with tread.
1 tyer is completely gone but still holds air.
The other 4 are good for skids or road but they aren't the best.
Rims are perfect, just a bit dirty.
$150 for all 5 rims and tyers
Hey dude
Can you send me a pic to 0401 227 678
Where you located? Tryed to PM you but it says you cant receive any more messages :/
Edited by Lock_to_lock
Hey dude
Just sent you a PM bud
Away for work at the moment, will be back tomorrow to send you the picture.
Cheers
Hi Guys,
Have some items listed on ebay, some not.
I have a RB26 complete with loom and comp, std injectors, -7 turbos, SS dump pipes etc $4000, if you are serious come talk to me.
http://www.ebay.com.au/itm/110799354439?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
http://www.ebay.com.au/itm/110799355919?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
http://www.ebay.com.au/itm/110799363806?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
After $450 for the advans, 17x9 and 100 for the strut brace. 0403431194 Located in South Australia
Cheers guys.
Hi Guys,
http://www.ebay.com....984.m1555.l2649
Cheers guys.
what offset are the rims ?
Items:Staggered set - Starcorp Mesh 18x8 and 18x9 - +38 offset I believe - originally off a 32 skyline
Item Condition:Good used condition - some gutter rash on one of the fronts, scuff marks here and there, the usual
Extra Info: Willing to trade for something of interest that will fit my new S15
Contact Details:Not on here much, call me on 0401636538
Price and price conditions:$600 or open to swaps
Edited by Sorin-Andrei
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
