Hi everyone the follow items are for sale.
APEXi Power FC with Hand controller - For a Manual series 1 R33 GTST - In great condition - $850
APEXi AVC-R Limited Edition boost controller with an additional new control valve and all instructions - In excellent condition - $500
Z32 AFM with plug - In great condition - $180
Jun rear Pods - Black - need a respray but other than that in pretty good condition - $100
PM me for more details :)
PFC & Z32 AFM sold
I will take $450 for AVCR with the extra new APEXi Solenoid included
all items located in blakeview SA
- RB25DET series 2 motor that has been previously opened as I intended to forged rebuild it, I had to move interstate so I loosely bolted it back together as the moving company wouldn't move an engine but they would move the car with or without it.
the engine does need to be rebuilt and will come with new rings and bearings, the intake manifold, throttle body, nismo 555cc injectors, a tomei cam gear on the exhaust side, gates racing timing belt.
the motor was on 107xxxKM before it was stripped.
the motor DOES need to be re built
$700 ONO or 800 with crane and stand
I also have a few other parts as well:
-extreme 6 puck solid button clutch with a extra heavy duty pressure plate, used but in near new condition - $300 ONO
-SPOOL H beam forged conrods to suit RB25 and 26. - $500 ONO
- SCA engine crane and stand, for both $250 ONO
-standard RB25 coil packs. $50 ONO
- R33 RB25 engine loom. $50 ONO
- all off RB25:
starter motor
power steering pump
alternator
aircon pump
flywheel
R32 engine mount brackets
STD AFM
cam angle sensor
clutch fan
↑ all
$20 each or make an offer
I am open to offers but please don't waste my time with ridiculous ones, feel free to ask any questions
PM me on here to get in touch
Up for sale is my 33 GTST - Bought another car plus want to buy a track car :)
cp5260468737259718030.jpg?width=376&heigcp5642116210025219562.jpg?width=376&heigcp4959864691568878461.jpg?width=376&heig
$8200 O.N.O.
Tasteful upgrades completed ready to be enhanced by power modifications or just leave it as a great daily that is legal.
Great interior and the previous owner put on a fresh coat of paint about 3 years ago.
The usual stuff can be said about it... Always serviced etc etc and all work done by known specialist mechanics that deal with imports. Receipts folder available to view work & service history.
What does it have/ what has been done;
-Major Service, belts and water pump at 100,000km
-additional oil/filter/tunes
-New coilpacks
-Headlights restored
-Voltage Stabiliser
-New dash cluster (old one had speedo stop working, new one was only 3000km out from the new one, I still have it to show KM's)
-Nissan Diagnostic cable
-New fuel pump (Walbro 255 L/ph)
-Sound deadening in doors
-Anchored pod filter
-Pivot Digital Speedo
-new platinum spark plugs
-lowered with new springs & KYB Shocks (it sits 15mm above legal)
-New windscreen (it still had the factory original)
-New right hand window reg and motor
-New tint
-Upgraded alarm system with built in turbo timer
-Full Nismo exhaust (Turbo back - straight through to muffler)
-New clutch slave and master cylinders
-Main seals done and running Redline oils
-Exedy H/Duty 1200KG Ceramic 5 puck clutch
-DBA 4000 slotted rotors all round with QFM A1RM brake pads (only about 1500km since brakes done)
-Reinforced pedal box
I do have a Apexi AVCR Limited boost controller but it has not been fitted yet. It is for sale separately at $450.
If you are after a skyline definitely worth a look at this one. I am a fastidious vehicle owner and it took me months and many many trips to look at skylines before I found this one.
R33 series 2 rolling shell for wrecking or track use only, cant be regoed. has complete interior and few extra bits and pieces ,auto gbox , wheels with decent tires on them, missing only engine package, it was an auto with 60something thousand k's on it.
Want to sell as is..
Asking $2000 negotiable so hit me up with an offer
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
