Sadly it is time to sell my 3rd R32
Mods
Engine/drivetrain
.Forged rb2530det - Registered with rb30 bottom end
.Kinugawa TD06H
.Stainless Tuned Length Exhaust Manifold
.FMIC
.K&N Pod Filter
.RB20DET Gearbox with NPC Cushioned button clutch (near new)
.KAAZ 1.5way Diff
.Oil Cooler and relocation kit
.52mm Core Alloy Rad with thermo
.Straight through 3" system with RSR rear muffler and custom dump/front pipe
Wheels/Tyres and suspension
.R33 GTR rims
.Rear tyres - 215 (RL Pirelli P7) (RR Toyo TEO Plus) on indicators but will be replaced with Zetum Plus tyres.
.Front Tyres - 215 Zetum plus (near new)
.KSport coilovers all round (height and dampner adjustable)
.Adjustable camber arms front and back
.Adjustable castor arms
Body
.Type M side skirts
.Factory sunroof
.Garden edge rubber front lip
.DMax roof lip
.Carbon wind diflecters
Interior
.Pioneer AVH-P330bt head unit
.Soundstream 6x9's all round
.Calibre boost gauge
.Nismo Gear knob
Alarm/immobiliser with central locking
Looking for 14k
R33 gtst gearbox 4 sale
Hi guys I have an r33 gtst gear box 4sale has had an overhaul done over a yr ago by award diff and gears. Always has been serviced with red line oil. Reason for sale just purchased a dog box so no need for standard box any more. Wetherill park 2164 $1600 neg post-120788-13902790034152_thumb.jpgpost-120788-13902790337785_thumb.jpgpost-120788-13902790629654_thumb.jpgpost-120788-13902790845532_thumb.jpg
For sale, need gone asap
r33 s1 4 door rolling shell, missing motor, box, ecu and door trims. Has plenty of good bits left, tien coils, hicas lock, aftermarket fuel pump, skyline floor mats, gtr drivers seat, slotted front rotors, 2 sets of wheels etc all panels are there. it was my daily for around 8 months but plans have changed
Need the space and dont have the time to mess around parting it out, looking for $1500 which i think is a pretty decent price
SOLD
sold the Hasa bicycle....
Need to sell a good gym-quality leg extension / hamstring curl machine
details & photo here: http://www.gumtree.com.au/m-my-ad.html?adId=1037059355
$150 ono.
These have been fitted with tyres and put car but never driven on so they are perfect condition , hyper black with polished lip 4" of dish , only selling due to a bit snug under rear of my stag with the amount of low I run .
Normally $552 + postage a pair from rota! sell $400 plus postagepost-76904-0-33306200-1390573943_thumb.jpgpost-76904-0-14636800-1390573968_thumb.jpg
GTR door trims F&R $200
GTR Front guards perfect need paint $400
GTR rear craddle bare $100
R32 gtr F&R brakes calipers & disks $600
R32 rear hubs, (perfect for 5 stud convo) $150
R32 Gtr sway bar $150
R32 3 way adjustable sway bar $250
R32 half shafts $ 50 ech
R32 F strut brace $80
NISSTUNE rb20/25 ecu $400
Rb25 stock low k bottom end $700
R200 s got a few $100
R32 GTR diff no centre $200
R34 GTT front brakes Bigger then 33 gtr $600
Excedy hd organic 25% left $50
Rb20/25 AFM'S $100
R32 rear knuckles $100
R32/s13/180 tailshafts $100
S13/180 cusco F strut brace $120
T25 rebuilt $150
R32/S13/180 stock camber arms $40
s14 stock toe arms $40
180 pop up light no head light $50
S13/180 doors both with glass n pwr windows $150
180sx bonnet $150
s13 Bonnet $80
180sx tailights n garnish $150 a set
Rb25 power steer pump $70
R34 auto converter n flexplate $50
R32 gts4 auto gb $200
R34 stock neo cams $100
Some cheap 17x8 +40 ish set no tyres some flat spots $300
Piaa Racing rims Multi 17x8/17x9 +40 $600
Work rims designed bye _ _ 17x9.5 bye +28 $1000
2x 235/45/17 rapid tres BN $180
13" skid tyres all above wear bars $15 ech
do you still have nistune and was it out of a r32 or r33 a or m?
Normally $552 + postage a pair from rota! sell $400 plus postage image.jpg image.jpg
What size are the rims and offsets
Just trying to get rid of some un-used bits and pieces I have sitting around. Not all car related. PM me if you're interested in anything and I'll send some info and pics. Located SE Adelaide Hills (Meadows, 5201).
Car bits and pieces:
3" mild steel catback to 4" SS AM Performance Twin Tips to suit R33 GTST - $350
RB25DET Harmonic Balancer to suit R33 GTST - $150
12" Sub Box/Enclosure - $20
Nissan non-hicas, non-airbag short solid bosskit - $50
Simota Pod Filter (brand new) - $20
BMC Pod Filter (used) - $5
R33/R34 Bonnet Lifters with Fittings - $80
2.5" to 4" Exhaust Silencer - $15
Genuine Nissan Crankshaft Oil Seals x3 to suit R33 GTST RB25DET - $60
Stock Nissan Silvia S13 Gear Knob - $5
DIY Hard Plastic Garden Edging Front Lip, 10m x 75mm - $20
Brand New Nissan Bolt on Spacers:
4x114.3 25mm - $95
4x114.3 30mm - $100
5x114.3 15mm - $90
5x114.3 30mm - $100
A few computer pieces:
Razer Naga Molten Mouse - $70
Logitech G510 Gaming Keyboard - $70
Razer Serious Gaming Mousepad - $10
PRICES UPDATED AND BUMP.
$150 ono.
Sold
Last thing for sale - Stagea S1 AWD auto
http://www.skylinesaustralia.com/forums/topic/438420-will-let-it-go/
follow the links, might be surprised at the affordability ;)
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
