Hello,
Recently had a Rocker Cover leak and changed over the gaskets. While doing this i thought it'd be a good time to change the coilpacks and spark plugs, as they were highly fragile and covered in oil from the leak.
After having to replace the original wires leading from the packs to the box (because they were rooted and seemed to have a different plug than the aftermarket ones) i found that the plug was also different that connects to the ignition box.
Having found that the wires are exact same colouration as the stock plug i just swapped plugs over making sure not to mix up any wires. This hasn't seemed to have work as when going to start the car up it seems to have its ignition out of cycle.
Anyone delt with this before or changed to aftermarket coilpacks that can help me out.
Thanks dewa32
Note: Pic comparing plugs is comparing the 6 pin to the 7 pin and not the one i've spliced.
Series 1 Cefiro use a unique ignition loom (inc ignition module itself)
Series 2 and 3 used the same loom as R32 Skylines.
You can buy both types of loom for the Cefiro new via Nissan.
S1
http://www.justjap.c...369&cat=&page=1
S2 onwards
http://www.justjap.c...871&cat=&page=1
I recall splitfire not having a listing that matched S1 Cefiro, so you'd need to get an R32 ignition module??, R32 loom, and coilpacks suit R32.
Quiet often, an R32 motor is chucked in, still using the Cefiro loom, plugs, ECU etc. That's how mine was anyway, when my coilpacks went it got a bit tricky - just wired up 32 plug to engine loom, and used complete R32 coilpack setup,.
Edited by Nic_A31
<br />Series 1 Cefiro use a unique ignition loom (inc ignition module itself)<br /><br />Series 2 and 3 used the same loom as R32 Skylines.<br />You can buy both types of loom for the Cefiro new via Nissan.<br /><br />S1<br /><a href='http://www.justjap.com/store/product.php?productid=18369&cat=&page=1' class='bbc_url' title='External link' rel='nofollow external'>http://www.justjap.c...369&cat=&page=1</a><br />S2 onwards<br /><a href='http://www.justjap.com/store/product.php?productid=17871&cat=&page=1' class='bbc_url' title='External link' rel='nofollow external'>http://www.justjap.c...871&cat=&page=1</a><br /><br />I recall splitfire not having a listing that matched S1 Cefiro, so you'd need to get an R32 ignition module??, R32 loom, and coilpacks suit R32.<br />Quiet often, an R32 motor is chucked in, still using the Cefiro loom, plugs, ECU etc. That's how mine was anyway, when my coilpacks went it got a bit tricky - just wired up 32 plug to engine loom, and used complete R32 coilpack setup,.<br />
Car is a 1991 Nissan Cefiro Series 1 by the look of the lights and grill. Which came from the factory with Rb20det. Car has not received any mods apart from r34 smic, pod filter and now the new coilpacks and has not been tampered with in regards to Loom changes (by the look of things)
With what you've writen there nic, I just have to get an r32 ignition module, and plug then rewire the loom side to the r32 plug?? Coilpacks are new, but were fitted to an RB20 in a s13 with r32 loom.
Cheers :)
Edited by dewa32
1991 is Series 2, so that's weird.
Biggest give away. Is your AFM an R32 one (green label, J60) or square plug (purple label, N60)
And yes, get an R32 module and the plug for the engine loom side, and wire that into your engine loom. Essentially, ECU Loom->R32 Plug->R32 Ignition Module->R32 Subloom->R32 Coilpacks.
true, well its got the series 1 gear, Also its a 'Special Edition' no idea what that means but could be the difference.
AFM is a purple label N60.
Will that need changing also or am i good just to replace loom and ignition module, as i already have subloom and coilpacks.
And do i need the whole loom or can i get away with splicing the r32 plug up to ceffy loom?
Thanks heaps Nic_A31 :)
Edited by dewa32
Afm plug is fine. N60 is a better Afm which the series 1 have.
Best bet would be a new coilpack loom. The heat makes them brittle and breakdown, so a new loom will definately help and be less probs down the track.
hey mate, i have just got a new coilpack loom thats no problem. MY problem is wiring the loom side up to thing, Can a A31 ceffy loom be wire for wire spliced into r32 plug then into r32 module?
Sorry about all the questions but yeah stuff me why nissan made the silver top run on s13 / r31 coilpacks other than the normal silver top plugs :S
mate went colour to colour and when i tried to turn her on it cranks over but sits really low revs and sounds like its not firing properly, When i put the throttle down too it doesnt rev up or anything also. all wires have been colour matched and plugged into the r32 module. What the hell ? :S
firing order is out a little or major misfire (by what it sounds like) It didn't die in idle, and i also checked the ignitor pack for heat because i thought i got the wiring for it was wrong but it didnt get hot, and all wires are colour to colour :S
Do you still think it could be the ignitor pack?
That being said it was only on for abour 30-40 seconds
Edited by dewa32
Try again for 2 mins and try another module. Also check the ground wires
Had a look at the cefiro coilpack loom and the r32 loom, and found out they had different colours going to different coilpacks. Had to swap green and blue, and white and yellow and redid all the grounds and she turns over no problem... So weird, Even they were matched colour to colour, plug for plug, there was still differences in Coilpack Looms :S. Tsk tsk Nissan. Cheers for all the help Nic_A31
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
