I have a set of Tein coilovers for sale. They are 'Low Down Spec Cool Style Master Type Wagon' (google for info) suit C34. They would suit either S1 or S2 RS4 Stagea. Good condition with no leaks. I don't know the spring rates but these type or coilovers are generally quite good for the street. No leaks. In excellent condition.
$1000 - 0433367570 - Taylors Lakes
https://www.sau.com.au/forums/topic/354287-fs-tein-low-down-spec-coilovers/
sorry i dont know much about stagea's as im selling these on behalf of a mate. so the coilovers i hvae are the eyelet rears? what model stageas will they suit?
second that, the ones on the right look like they could be c34 auto rears (eyelet bottom, 2 stud top plate) but the ones on the left don't look c34 stagea (3 stud tops would suggest s2 rs-v rear wheel drive but nfi what those things at the bottom are)
are they the actual set you are selling or just a pic you stole from the internet?
  • Like 1
they are the actual set im selling mate
Next time please make sure you know what your selling, If it wasn't for the guys picking it up, some one could have unknowingly bought them.. :thumbsup:
Edited by Garage_Kaizen
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
