I brought a R33 4 weeks ago with a AVC-R fitted. The car was tuned in Sydney by a tuning shop with the setting ; A@8psi, B@10psi.
The car has been great, goes well etc, but a week ago when I turned on either one of these settings then place the car under load I now hear this ticking sound from where the ECU is situated(in front of the passenger's feet). It's like a relay clicking on & off.
Secondly, is it a standard for the display unit itself, when turned on to retain a lot of heat? When I touch the back of the unit, it seams to hold a fair amount of heat. Is this common with this system?
Any help on this is much appreciated
https://www.sau.com.au/forums/topic/35455-help-on-apexi-avc-r/
They are pretty quiet compared to other ebc's. I am hoping that the ticking noise is just the valve for the ebc, mine is located in the engine bay, they make the noise when you start boosting. The screens are really hot that's normal.
The AVC-R Boost Control Solenoid is usually mounted inside the engine bay. The ticking noise is normal when booost comes in. You can make this noise less noticeable by placing a flat rubber strip around 3 to 5mm thick at the base of the solenoid to cushion it from wherever it is mounted. I have made an mounting platform like an "L braket" out of 5mm aluminium strip to mount the solenoid properly, again with rubber cushion between mounting platform and solenoid for to recude the noise. This method also extends the life of the solenoid.
Heat from AVC-R control screen is normal.
If you require any further assistance regarding the above please contact me. Oh I sell APEXI products too so call me if you need anything.
Cheers!
ARNIE - APEXI8
APEXIATE!
Thanks for the advice. It's always a sigh of relief when here good news that all is fine. I had a closer inspection of the manual & found the heat periameters for the display unit.
I'm looking at upping the boost soon a few pound. I'm after 260rkw from which I'm told is quite easy with my current set up. I'm having it sorted through a shop to avoid any expensive mishaps, fuel rate being the key factor.
I will be looking at the apexi monitor which has rpm cutout & km/h in the next few months. If you have a price on this, let me know
Thanks again
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
