It's time for another dinner guys so please join us this time at the Hackney Hotel. Dinner will start at 7PM so you'll have plenty of time to freshen up after work to make it for a good feed. This is open to both members and non members so please come down and spend the evening with us. If you enjoy it, maybe even think about joining as always we will have sign up forms with us on the night.
If you could register your interest and if you are bringing any extras that would be great as we need to know rough numbers to let the Hackney know how many to expect.
Hackney Hotel Info
Confirmed
heslo - Luke
Madaz - Steve
RBWARE - Shane
SLED - Pete
RubyRS4 - Reuben (maybe)
Nightcrawler - Andrew
scandyflick - Dave + 1
Jap_star - Josh
Matty T +1
Luke_ENR34
Brezza - Michael
typevu - Vu +1
Dano_R34 - Damo + 1
RBJETT - Steven + 1
Krishy +1
rad32 - Adrian + 1
Fliggy - Tim
skwiz - Jake + 1
Volk34 - Lewis
Evil34 - Shaun + 1.2
Aberax - Abe
dark.sky - Dion
normsta - Norman
writeoff - David
Ripp3r - Jeremy
Jenkies - Mark
Kraft - Steve
Tangles - Brendan
  • Like 2
https://www.sau.com.au/forums/topic/354572-sau-sa-dinner/
