Hey guys, i have a few dents (scrapes) in my car, and a few scratches also, some where the paint has completely been sliced off, and a small amount of rust has started to build.
I was just wondering, whats the best way i can remove the dents, AND fix scratches. Im on a low budget at the moment and need to find the most efficient way.
Also im not too good with this stuff, so details would be really appreciated. And hopefully with the help i get, i can restore my baby back to mint condition again :)
Thanks :D
depends on your colour and the depth of the dents.
black is a bitch (just ask me). White is waaaay easy and silver also not too bad.
Honestly you cant go past a good dent popped and detailing job performed by a professional. Especially if the dents are as strong as you have indicated and also you have rust begining.
I just had a monster 50c piece sized dent popped professionally. Cant even see any trace of it anymore and that is on a black car n the dent was on a very visible section.
Good luck
try and find a good paintless dent removal (PRD) person in your area, let them fix as much as they can and then head to a panel beater for a quote.
If you're down to bare metal unfortunately it's paint time. Depending on how fussy you are/how big the affected area is, you can try a local touch-up or you'll have to respray and depending what part of the car, the panel beater will have to blend in the new paint to the rest of the car.
Very important you find a good panel beater
Hey thanks for your help :) i got a quote today to fix everything on my car, and it was close to $2000, but that included painting scratches on the bumper and a large scrape which needs to be filled. But just to fix the dents it cost $450 alone. So idk whether to just get the dents done, and bog and respray the scrapes and larger dents. I cant afford 2 grand. so thats looking pretty good.
I would highly recommend provident crash repair at magill. Friendly service, flawless colour match and they have a few imports go through so they understand our passion. Also no unexplained added kilometres to the odo which I am always very anxious about..
thanks for your help but im located in WA, but you informed me on added k's to the clock which i'll now be weary of. i dont want them taking her for joyrides!
  • 1 month later...
they might not have to blend it if taken to a crash shop, it all depends on how well they can colour match + if its a metallic then it will need to be blended. just giving my 2cents as im in the crash repair industry
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
