After the rebuild I have a few items available to the needy. 10% of sales to SAU. Offers considered. Added some low res pc cam pics (I know, I'm cheap). Postage extra or as negotiated.
Added HICAS lock bar to offer - $100 plus delivery and $10 donated to SAU
Conrods x 6 - linished and polished sides, #3 (therefore all 6) need resize due to bearing run, this doesn't cost much at the machine shop - $100
Pistons stock 0.5mm OS x4 good cond 20K the other 2 are cracked - $50
Fuel pump stock GTS25t (replaced with GTR item) - $100
Nismo Steering Wheel - Nismo horn button Good Cond 3 spoke no centre pad bolts straight up to R33 GTSt - $100 SOLD
Greddy style fibreglass twin A pillar mount - 65mm black in colour, not used due to loss of vision on the racetrack, would be OK for road but doesn't suit me for race, fits over standard a pillar trim without needing to damage std trim- $120 SOLD
Hicas rear steering unit - $100 SOLD. I don't need it anymore:D I can also fabricate the Hicas Lock bar to get rid of rear steering, same price.
Stock Intercooler - $50 no hose fittings
Auto trans shifter surround Corbon Fibre finish - $30. Originally wasn't in great condition so I layed up carbon fibre over the base. Doesn't look as good as the pics, hence the low price.
Help me clean out the garage and help this great forum that has provided for me so well
As you can see I now have a digicam...but got it cheap:D
  • Replies 40
Not yet, still got a few things to finish off like pfc and tuning after run in. Plus finalising a few compatibility treasures I discovered.
No pics, runs from the base of the A pillar to the top of the A pillar. Never installed, just smoothed the holes for the guages to seat nicely.
Added some lo res pics. Not allowed to buy a decent camera so had to use web cam. Something to do with how much I spent on the engine build :(
I still have all the parts, was eyeing off the guage holder for some severe butchery but other jobs have given it a stay of execution. It's yours if you want it.
EnricoPalazzo, the wheel has a Hicas boss and fittings for the horn.
All negotiable.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
