I just bought a nismo autech rear wing to find it has different mount positions . Has anyone installed one before or know how to go about it ?
Perhaps try Ruby, he has a "Nismo" stag.
its says nismo and autech here is the link on ebay , http://cgi.ebay.com.au/NISSAN-STAGEA-AUTECH-260RS-REAR-WING-SPOILER-NISMO-/230468182057?pt=AU_Car_Parts_Accessories&hash=item35a8f96029 i spoke to the guy who made it and its an exact copy ,Tell me what u think. The mounts are exactly above the bolts of the hatch.
theres legit noway to mount this kinda shit without glue of some sort... theres NO room at all... remove the trimming from the rear window n c the little hole... its hard enough getting the old one off!
Here a pic of the wing on the car
Pic of the hole's i put in the hatch used all three of the mounting pionts and double sided tape. Some how with the air flow over it i don't trust just glue or tape alone but that's just me :).
and this is the factory hole's i'ved tape them up for now trying to get the factory covers for them
The mark are from the factory spoiler and the tape thay used.
Cheers
Yup in the last photo the tape covers up the factory mounting holes from where the the spoiler was. Getting them from japan for $30 bux each will get a photo when there on the car.
also getting some rubber gromets to cover the holes inside the hatch.
Cheers
  • 3 months later...
Cheers
Any progress with the paint job
ouch - for what it's worth i'd be putting the stock wing back on. the holes look nasty.
does anyone know if the holes between the S2 stock wing and the S2 Dayz wing match up? i wouldnt mind replacing my dayz wing with a stocker - a bit cleaner, a bit less 'look at me'.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
