I just bought a nismo autech rear wing to find it has different mount positions . Has anyone installed one before or know how to go about it ?
Perhaps try Ruby, he has a "Nismo" stag.
its says nismo and autech here is the link on ebay , http://cgi.ebay.com.au/NISSAN-STAGEA-AUTECH-260RS-REAR-WING-SPOILER-NISMO-/230468182057?pt=AU_Car_Parts_Accessories&hash=item35a8f96029 i spoke to the guy who made it and its an exact copy ,Tell me what u think. The mounts are exactly above the bolts of the hatch.
theres legit noway to mount this kinda shit without glue of some sort... theres NO room at all... remove the trimming from the rear window n c the little hole... its hard enough getting the old one off!
Here a pic of the wing on the car
Pic of the hole's i put in the hatch used all three of the mounting pionts and double sided tape. Some how with the air flow over it i don't trust just glue or tape alone but that's just me :).
and this is the factory hole's i'ved tape them up for now trying to get the factory covers for them
The mark are from the factory spoiler and the tape thay used.
Cheers
Yup in the last photo the tape covers up the factory mounting holes from where the the spoiler was. Getting them from japan for $30 bux each will get a photo when there on the car.
also getting some rubber gromets to cover the holes inside the hatch.
Cheers
  • 3 months later...
Cheers
Any progress with the paint job
ouch - for what it's worth i'd be putting the stock wing back on. the holes look nasty.
does anyone know if the holes between the S2 stock wing and the S2 Dayz wing match up? i wouldnt mind replacing my dayz wing with a stocker - a bit cleaner, a bit less 'look at me'.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
