Gonna miss this next one...will come around in August if you guys still meet :P
Don't feel bad mate.
No doubt I will come up with some sort of a lame excuse as to why I didn't go either :P
  • Replies 216
Yeah, but Hank, there are only so many times you can recieve the text "Soz, trying to staunch some rectal bleeding, wont make it to brekkie this time" before it becomes meaningless ;)
  • 4 weeks later...
  • 4 weeks later...
  • 2 months later...
Yeah, that was kind of why we settled there.
I reckon there is probably some better value about the place though.
Anywhoo, I will try to be there. If anyone n00bs show up, I will be the hobo out the front panhandling :(
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
