Over the years when i used to do parts i ended up left with these remaining items in my personal stash. please take a look and make offers if you need any of the parts to my email [email protected]
parts are in Australia and can deliver asap via Australia post.
If you require photos please email me asking and i will supply the pix you need as i already have most on file i did today.
Reasonable offers i know what these parts are worth but want them all gone as i dont wish to move with these once again.
Once i have sold any of the parts i will put SOLD beside it.
apexi turbo timer with nissan plug $20
arinx pod filter $10
bee-R bov with pipe $80
blitz bov with S13 pipe or cefiro $80
Blitz turbo timer $20
VH45 air flow meter x 2 $300ea
Alpine splits set $50
CA18det crank angle sensor $75
R33 x2 S2 coils with harness
R32 coils x6 with harness
CA18det coil x 1 with harness
Defi boost guage kit $150
dildo gear nob large and yellow $20
Forza weighted gear nob $20
RB26DET coils x 6
R33 GTR computer harness $200
HKS pods x2 $20
N1 oil pump used $150
Proff BOV with polished R32 intake pipe $150
R31 Crank angle sensor Nics type $50
R31 Igniter nics type $50
R32 AFM X2 $75 ea
R32 castor/radious rods solid drift type $100
R32 igniter x2 $100 ea
R32 air vents center $75
R32 crank angle sensors x 2 $75 ea
RB20E Crank angle sensor $20
Silvia air vents S13 type set $75
R33 AFM $100
R33 radio brakets x2 $10 ea
delica radio brakets x 2 $10ea
delica touch screen
delica touch screen climate control system
SR20det Crank angle sensors X 2 very hard to find $250
Sr20det igniter $150
Tein Spanner set with allen key adjuster $20
TV monitor mirror (good for reverse camera or dvd) AV inputs only. $10
I will edit the list here as i cannot edit the original post
apexi turbo timer with nissan plug SOLD
RB26DET coils x 6
HKS pods x2 $20
R32 AFM X2 $75 ea
R33 AFM $100
delica touch screen
Edited by PRIMO
hey mate where u located interested in the tien spanner set n maybe the apexi tT can pick up if in melb
shoot us sum pics
ty
Apexi turbo timer it has been sold sorry
Tien spanner set avail still you can pic it up from WA if you like 6210
Edited by PRIMO
how much is the tv monitor mirror postage to brisbane and if you can please send some pics that would be great
postage should be $15 approx
Defi boost guage kit SOLD
dildo gear nob large and yellow SOLD
RB26DET coils x 6
HKS pods x2 $20
R32 AFM X2 $75 ea
R33 AFM $100
delica touch screen
RB26DET coils x 6
HKS pods x2 $20
R32 AFM SOLD
R33 AFM $100
delica touch screen
Blitz turbo timer SOLD
RB26DET coils x 6
HKS pods x2 $20
R32 AFM $125
R32 igniter SOLD
R32 crank angle sensors x SOLD
R33 AFM $100
delica touch screen
Hi,
Can you post a pic of the bee-R bov with pipe?
And how much are you chasing for the RB26 coils? are they from an R33 GTR? Pic?
Cheers
mate il take the tv monitor mirroir if u could text or call 0406022670 to sort payment and postage or email me [email protected]
email sent
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
