we got that too!
well... not atm due to dns probs.. but the site is still located at www.skylinesaustralia.com/nsw (and once dns is fixed nsw.skylines... )
Duncan - yep, he'll have a login for it, so they'll all be listed on there.
https://www.sau.com.au/forums/topic/35545-wwwsaunswcom/#findComment-709362
Merli, it was a case of using a URL in the short term that we can use on merchandise an not need  to seek approval from Nissan. Working around the problem. :D
HAHAHAHAHAHAHAHAHAHAHAHAHAHA!!!!!
:);):D :D
https://www.sau.com.au/forums/topic/35545-wwwsaunswcom/#findComment-709385
Nice start, yeah.
Have we thought about making the change permanent ? ie Skylines Australia NSW ----> SAUNSW ???
Might fix a lot of problems ......
* Nissan Approvals every time we need do do something
* More perceived seperation between the Club & the Forums
* What happens in 10 years time when Christian is running 350ZAU ?? The club benefits from it's own seperate domain in many ways.
My 2 MilliYen
Were we able to register saunsw.com.au ???
I know I'll get used to it, he he but when I see saunsw - I read University of Sydney, South Australian campus. Silly I know, UNSW is synonomous tho.
https://www.sau.com.au/forums/topic/35545-wwwsaunswcom/#findComment-709899
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
