hey everyone, have started this as i want to share my build with everyone and hopefully inspire someone or get some advice along the way,
where to start... it a 1996 Gts-t manual, had it bout a year now and have done a little here and there, just the usual stuff THEN....
started getting mad boost spikes ( standard turbo ), searched the forums did a few quick fixes and no success, then one night on the way home from work it failed..
i am a mechanic at a Truck joint in melbourne so i have the luxury of having a S&^T load of tools but unfortunantly nowhere to leave my car, SO i rent a storage garage and perform all my work there,
its far from perfect but will have to do as my folks wont have it in the drive way.
this is how it was before i decided to go crazy on it
ok first of all ill show what i have done in the engine bay thus far, as i have some ok pics of my progress in that area
Removal of turbo, lines, Exhaust, manifold.. and replacement of the studs to shortened ones in prep for my 6boost manifold
had an absolute blast getting the studs out including two snapped ones and cleaned up the block and surrounding area while that side of the motor is apart...
next is the inlet. new plazmaman plenum in raw billet finish... is quite an easy fit, all i had to do was drill out the threads on the far l/h side of the lower runners and fit plenum, there was obviously mods to fuel lines, water and vac hoses and i extended some wiring but overall an easy install,, and how bout Plazmaman product quality!!! SWEET plenum.
then i decided to paint cam covers as i was out of stuff to do that night ( still waiting on parts ) came up nice i think...
other things sitting around atm are some rays CE28n i bought AGES ago and have not got tyres for yet and some 33GTR wheels i bought of here, new boost gauge and a few other things, turbo manifold and zorst are sorted but wont be ready for a while but im having a ball..
will post up every few days hopefully.
https://www.sau.com.au/forums/topic/355479-my-paulos-ecr33-build/
just a few other things i have been doing while waiting for parts...
having fun repairing thread in head for exhaust manifold studs
removed gearbox a few knights ago for a new clutch.. the old one was not slipping but once removed you could tell it doesnt have much life,
i decided to change the clutch while everything is apart instead of replacing it after it fails on the dyno.
polished up my headlights this pic is before the final polish as my camera batt died but holy crap they came up way better than i thought cos they were so brown
measured up where i want my ps reservoir, air box is there as i have not decided whether i will use it or not so i want to make sure it will still fit... sorta need the turbo bolted on to finish this though...
im also in the process of putting carpet in the back, the centre was pretty easy and im up to the wheel arches atm, should be nice when done hopefully a lil different too
got news that manifold is nearly ready, wastegate is on its way so is turbo and intercooler piping. dont know when ill get them but hopfully in the next few weeks.
Edited by PaulosECR33
got my turbo on friday its a gt3082 with a .63 housing, also got a oil and water line kit for it.. hopefully manifold this week or next and things will get moving again..
tbe hardest part is waiting for the money to buy stuff lol...
things i will be getting in teh next few months will be
-New radiator bigger core maybe a 2 pass if i can get one.
-1.5 way diff
-brake upgrade, only tonight i read up on d2 8pot upgrade and that looks ok, but for now it will probably just be pad and new discs, maybe 326mm with caliper spacers.
-exedy hyper single clutch
-found this cool looking catch can/washer bottle on just jap, bit pricey though although not as expencive as the rips one
-suspension setup. am lost with what to do here , it will be street driven to and from the track and im interested in drifting it so will have to look in the suspension forum to check out what i need there.. from my experiance in making commodores slide i need a tight as fcuk rear end and a loose front and more negsative camber induces more oversteer on the front, will have to do some research for the 33 though
-i am also keen on getting a fake gtr front bar as i like them better.
when i get the manifold ill post some pics of fitting her up & the oil and water lines to the turbo
  • 6 months later...
ill try to bring this back from the dead.
no money and no parts make sh1tty posts but i have actually done something over the last few months
anyway ill get back into it, i have decided to get a vipec first of all, ordering soon but heres what has happened
Got Turbo Gt3082r .63 rear housing
Got 6boost manifold & heat wrapped
fitted manifold and turbo
took off manifold are redid crappy heat wrap.......
bought heaps and heaps off fittings, collant hose, braded hoses -3 & -10, power steering hose and efi hose god damn they cost a lot.
bought a surge tank and 044 for the boot, stripped boot and fitted out, (yet to be wired) used up 4m of efi hose & tried to make it as tidy as possible i think it came out pretty good.
got those sexy ce28s wrapped in rubber, Toyo T1 proxis on front (225s on 8,5 inch wide) and 2nd hand continental tyres on rear (265s off mercedes demo cars got sick price with like 90% tread, onto 9.5 inch rears)
fitted my new Boost, oil pressure, coolant temp & oil temp gauges (clearly they dont match but i like that for some reason)
somehow convince my Mrs (who wen i bought the car told me she hated it and said it was the worst car ever) that skylines are ok (getting there shell come around).
Finished off clutch & put bos back in Etc, ended up going with a backyard flywheel machine with buff gun & an exedy Triple HDB clutch
thanks to Northern Brake & clutch.
Ended up going the Caliper spacers with standard calipers and gtr rotors although i dont have any rotors yet.
Those spacer are pretty damn good quality. pretty sure i wont be able to fit standard 16 inch wheels back on front though, if someone who has done this mod could let me kno that would be good..
"Vertical Hood" mod cos i was sick of not being able to see the back of the eninge (go to google images & search "vertical hood", go, you kno u want to..... R 18+ warning)
Charged my battery, changed oil & filter, put sandwich plate for oil sensors, put coolant in ( no radiator just yet ) fitted waste gate....
got cooler pipes made which was a mission for some reason..... anyway, mocked up an intake that will be ok for now...
fitted cooler piping & intake & afm, made up a dump pipe bout 12 inches long to put o2 sensor in,
and here is where im at
may not seem like much to some but bills come before toys & money is tight...
car runs pretty good once i got some new fuel in it, cleaned out idle control valve & adjusted clutch.. no leaks all gauges work waited for the smoke from the heat wrapped i handled to much to go away & everything seems good..
have got a different p/s bottle now just need to weld some fittings on & hook up some lines, made up a bracket to fit & should be all good,
got some jecs750s (i know they are probably high flow haters go ahead and hate) will see how they go once the vipec arrives. can also get rid of afm then
thanks dude its getting there
did a little more stuff today but no pics atm
fitted some phillips crystal vision low & high beam globes with led parkers look much better than origional globes.
run my final lot of vacume hoses, for waastegate, FPR, boost gauge
fitted my coolant temmp sensor adaptor.
ran my p/s hoses & insulated from heat/rubbing and fitted a belt.
got a really cheap little pod dilter to fit the engine bay while the afm is still needed
will hopefully get my P/s bottle back with some fittings welded on soon man i got to buy a tig....
only problem is that my radiator bung has gone missing lol anyone kno where to get one i checked ebay & most of the usual sites and went to repco & autobarn with no luck
  • 1 month later...
well i found my radiator bung lol. finished my exhast and drove it.. had problems with idle. all ok now i have pretty much finished for this year all i need now is my ecu. got a wideband and knock monitor ready to plug in once i start tuning...... fuel system connected, new injectors in i moved the engine loom to underneath the inlet manifold and it looks much neater. also painted the rocker covers & coil cover gloss black..
when lowering the old girl the found the front left and rear left shocks to be stuffed, so i went nuts and got some tein super streets. from teh limited driving i have done thus far im amazed at how smooth these coilovers are, of course tehy are on their softest setting atm... oh yeh i have to roll my guards too so i can get some stnace eventually.. im sure next year will bring more moments of being bankrupt but thats next year, i just want it driving and tuned this year..
NEARLY THERE
here is one of where it all started in my lonely little rented garage..
now here it is as of yesterday. am very pleased with how its turned out so far
Painted up rocker covers and sort of cleaned up engine bay
im sure everybody knows who these two chums are. they are going to be waving bye bye to1 lots of cars in the future hopefully lol. i asume mostly australian cars with american engines ( i can say that i have a maloo )cheers.gif
the height is nice but once i roll the rear guards and pull the front inner guard covers out ill drop it.. but for now im happy with the height
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to it's full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so damn hot in there, that made it all the more easy to remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. I was standing there looking at the car and said 'f**k it'. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
