GT-T 1998 Posted February 28, 2011 Share Posted February 28, 2011 ive got a coolant leak and i cant find it .. does coolant run through this pipe in a rb25det Link to comment https://www.sau.com.au/forums/topic/355578-coolant-leak/ Share on other sites More sharing options...
rgr34 Posted February 28, 2011 Share Posted February 28, 2011 no coolant in that pipe.. Link to comment https://www.sau.com.au/forums/topic/355578-coolant-leak/#findComment-5692382 Share on other sites More sharing options...
GT-T 1998 Posted February 28, 2011 Author Share Posted February 28, 2011 ohk .. do u no wat is in it Link to comment https://www.sau.com.au/forums/topic/355578-coolant-leak/#findComment-5692388 Share on other sites More sharing options...
Aleckr33 Posted February 28, 2011 Share Posted February 28, 2011 (edited) You wanna hope no coolant is running through that pipe... that's for sure. But no, no coolant runs through that. It's your oil bypass/overflow back into the head. Edited February 28, 2011 by Aleckr33 Link to comment https://www.sau.com.au/forums/topic/355578-coolant-leak/#findComment-5692390 Share on other sites More sharing options...
GT-T 1998 Posted February 28, 2011 Author Share Posted February 28, 2011 so prob need to be changed then i guess Link to comment https://www.sau.com.au/forums/topic/355578-coolant-leak/#findComment-5692398 Share on other sites More sharing options...
Aleckr33 Posted February 28, 2011 Share Posted February 28, 2011 (edited) It is leaking, lol. It's got a nasty split in it... Edited February 28, 2011 by Aleckr33 Link to comment https://www.sau.com.au/forums/topic/355578-coolant-leak/#findComment-5692400 Share on other sites More sharing options...
GT-T 1998 Posted February 28, 2011 Author Share Posted February 28, 2011 lol i just had a major service a month ago driven it 2000kms and coolant is leaking from somewhere cant find traces and this pipe is cracked Link to comment https://www.sau.com.au/forums/topic/355578-coolant-leak/#findComment-5692405 Share on other sites More sharing options...
Aleckr33 Posted February 28, 2011 Share Posted February 28, 2011 If you have checked both hoses and no leaking, Check your radiator cap or look around the radiator for cracks. Link to comment https://www.sau.com.au/forums/topic/355578-coolant-leak/#findComment-5692419 Share on other sites More sharing options...
rgr34 Posted February 28, 2011 Share Posted February 28, 2011 have you taking it back to where it got serviced? Link to comment https://www.sau.com.au/forums/topic/355578-coolant-leak/#findComment-5692421 Share on other sites More sharing options...
marksuxass Posted March 2, 2011 Share Posted March 2, 2011 Take it back to where you got it serviced. Ask them to do a cooling system pressure test. It may also just be a bit of residue from where they drained the coolant and havent cleaned it off properly? Link to comment https://www.sau.com.au/forums/topic/355578-coolant-leak/#findComment-5696675 Share on other sites More sharing options...
FTO Posted March 6, 2011 Share Posted March 6, 2011 It will be the water pump if it was done on a major service. Sealing those things without a gasket is a hit & miss affair. And if an RB30 pump was used, it will leak where the top bolt doesn't line up...my guess anyway. Link to comment https://www.sau.com.au/forums/topic/355578-coolant-leak/#findComment-5701430 Share on other sites More sharing options...
GT-T 1998 Posted May 26, 2011 Author Share Posted May 26, 2011 ended up being the apprentice that worked on my car and had a air pocket in it or something n got fixed for free Link to comment https://www.sau.com.au/forums/topic/355578-coolant-leak/#findComment-5834683 Share on other sites More sharing options...
