I've noticed lately that there is a fair bit of black smoke comming out of my exhaust when I give my car a hard time, just wondering what the cause may?
Could it be it's running too rich or a more serious problem?
Motor is a croydon built 26 with t88 with full 4" exhaust.
Happens on low and high boost 15 psi & 26 psi.
Any help is greatly appreciated
https://www.sau.com.au/forums/topic/355851-black-exhaust-smoke/
Could just be blowing a bit of build up out.
Or just a bit rich on the tune, which isn't necessarily a problem. I leave a bit of a cloud when on a full throttle tramp.
if you worried, go stick it on a dynoto get things looked at.
or just stop looking in the rear view mirror!
Does it do it on both high and low boost. I have tuned a few cars that ceoydon tuned 1st Nd on power is tuned perfectly bu the cruise tune is crazy overly rich. Sometimes richer than when on full boost. If urs is the same then it would be a build up of fuel and carbon in the cylinder, then when u boot it its cleaning it out.
Check turbo gaskets (if that's the right term) ... guy at the lights had a "blown turbo" which blew black smoke.
Friend had a 300zx (twin turbo) with a f**ked gasket. Put a liquid in as a temp fix and was safe to go until that happiness wore off.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
