OK, I dont really know sh*t about turbos :-} but have been reading recient posts to try to build up my Knowledge.
From what i have read the GT2530 is a good responsive turbo that can make about 250rwkw.
My current perf mods are:
3' turbo back zaust,
zaust cam gear,
cold air box with pod,
FMIC,
PFC Pro,
ceramic button clutch,
supra twin turbo fuel pump jap spec (was told that they flow better than GTR ones by far, maybe somebody can varify that?)
NGK irriway7 plugs.
I think thats it.
I would like a turbo that doesnt lag any longer than 3,500 but still comes on boost hard. I plan to get new injectors and a z32 afm in the future but not for awhile. My car currently makes just over 200rwkw on the standard turbo, what turbo whould make a good replacment for me?
any advice would be great thanks.
https://www.sau.com.au/forums/topic/35589-which-turbo-for-me-help-please/
try gcg turbos 0418645461 in canberra they do a high flow on yours whilst there at it, it gets new roller bearings new steel exhuast wheel so big boost is possible(ceramic wheel wont shatter)and apparently will do just as good as 2530 and costs bugger all in comparision
you wont need a fuel pressure reg if you are doing injectors.
probably better off with a 2535 or 2835 than 2530, as it will make the power a bit easier.
$1550 is a bargain for a second hand HKS turbo, even if it needs rebuilding it will be a better price than new. you can also sell your stock turbo. It will be a good idea to upgrade the pipe from AFM to turbo to, so anther $150-200 there, then similar may be needed for turbo to cooler. Oil and water lines, $300 or thereabouts. Injectors around 1K. AFM around $350 with a plug.
be ready to pay around 5-600 for a full remap with the injectors too.
good luck
I have started to think that if I am going to spend around $4000 on a 2535 setup then I may as well save up a bit more and go for something like a GT3035 or something alike...
Does anybody out there have a setup like this? & what are your experiences with it, eg power, boost, spool up time and so on & what price range would I be looking at for this?
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
