Brett at autoworx just recomended the PCPA turbo's to me for my rb25det however as i mentioned to him im a bit cautious of them. he said he has one on his r32. has anyone else used one of these turbos. i was going to use the atr43g3 from hypergear however im just curious about these pcpa turbo's what are your thoughts
https://www.sau.com.au/forums/topic/355944-pcpa/
How on earth did you manage to write that out twice :blink:
Yeah I have never heard of them either. I really don't understand why people go towards random unheard of turbochargers when the ones that are proven time and time again at the end of the day aren't that much dearer. Given that 9/10 times a "cheap" budget turbocharger doesn't fit properly and requires a custom dump pipe or spacer plate or custom made oil and water lines, usually ends up being just as much as a bolt on Garret or Hypergear kit. Not to mention than you don't get the power you want and end up selling it 6 months later.
https://www.sau.com.au/forums/topic/355944-pcpa/#findComment-5697439
sorry guys i have no idea how that came out twice it was a copy and paste so dunno but like i said im going to go the hypergear i was just curious. about them thats all i rather something i know has been proven time and time again
https://www.sau.com.au/forums/topic/355944-pcpa/#findComment-5697459
I just did a google on the PCPA turbochargers. PCPA is the name of the website (maybe shop aswell, didn't really look into it that much) that sells them. Not the brand of the turbochargers themselves.
http://www.pcpa.com.au/index.php?main_page=index&cPath=21
So the turbochargers appear to be just a typical no name brand ebay spec turbo like the rest of them.
https://www.sau.com.au/forums/topic/355944-pcpa/#findComment-5697468
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
