MY PARTY?!?! WHO WHAT WHERE WHY HOW!?!? Not not my idea, it was strutto/MJ/nexus9's first idea, I just show up and perform death defying stunts that leave cars with 3 wheels :D
Yeah some people have hinted at doing another mountain run, so I was just the first home to post the thread :D
https://www.sau.com.au/forums/topic/35630-what-to-do/#findComment-711459
Dats what we did tonight, but majority rules, and the majority want this, something different. Tonight was a nice leasurly cruise in, cruised out took some pics, then cruised over there, watched some nice rides idle past and talk crap about stuff and then nice cruise home :D
But maybe a cruise into main beach next time for GC turn, maybe.... see what everyone thinks, why not start organising the 25th it's not hard :D
https://www.sau.com.au/forums/topic/35630-what-to-do/#findComment-711474
Ska your a N00B :D
MindFlux... Cruising in GC city hasn't happened cause none of us really want to be raped by the cops down that way...
And Thurs nights pretty much suck on the Gold Coast...
And it's not real fair on the Brissy people to have to travel so far...
But if you wanna organise a Thurs night GC cruise to BWCP... Go right ahead... I'll come along...
https://www.sau.com.au/forums/topic/35630-what-to-do/#findComment-711519
Yes I know I'm a n00b but still there is only one way I am going to learn, and that is to be taught, so is someone going to tell me what BWCP is because it is waaaaay too late for my brain to be functioning at any decentlevel, BAH I'll try working it out tommorrow, night :D
https://www.sau.com.au/forums/topic/35630-what-to-do/#findComment-711522
strutto i hear tiy .. but its likewise for the qeenslander, aoaer from it beign a long ass drive to get up to bris ban (please excuse me the tabelet is starting to kick in+
uhhhm where esd i ...
uhhh what wehre you ytaljing about? ,,,
oh yes the crusing and the brisbane and the guld coasy
mate im so ****ed i nill call you tomorrome
i think
sebnd
send
.end
exit
https://www.sau.com.au/forums/topic/35630-what-to-do/#findComment-711563
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
