its the gayest multiplayer game ever, i have so much trouble with it, takes about 2 clips to kill someone when they have armor on, or 4 shots to kill you with armor off, terrible experiences, and quite boring, its a mix between halo, and call of duty.
played the full game thou, and the single player is very good from my view
https://www.sau.com.au/forums/topic/356321-crysis-2/#findComment-5704584
from what i can see is its a port so you don't get heaps of gfx tweaking it asks you mode's you want like advanced, gamer and extreme
Jean i tend to agree i keep dying and have no idea how other people don't seem to have recoil
and sprint is too fast for my liking
it is a pretty game though
https://www.sau.com.au/forums/topic/356321-crysis-2/#findComment-5704649
yes, agreed, the game is very pretty, but not very cpu intensive, but then again, i dont know how to unlock the dx10/11 feature. all those modes only go in dx9 mode, everything maxed out @ 1920x1080 i get an average of 60-70fps, so i guess its engine has improved alot.
but game has not been 100% finished yet and more options are yet to come.
also, the way you use the nano suit is a total ass!!
i really dont like it compared to the old game.
other than that....... it EYECANDY TIME!!!!
Edited by Bronx
https://www.sau.com.au/forums/topic/356321-crysis-2/#findComment-5707032
  • 3 weeks later...
yeah you should, but i dont know how many ties you can install the game till it becomes a invalid cd key, most companies have a5-10 install limit before it locks your cd key and makes it invalid, but then they usually have a revoke tool for stuff like that, like far cry 2
https://www.sau.com.au/forums/topic/356321-crysis-2/#findComment-5736263
[quote name=ClutchBurndout-:(' timestamp='1301958060' post='5746064]
will probly grab this one, gamespot give it great reviews
cant however buy on pc since it pretty much wont run, so say bye bye multiplayer :(
Multiplayer actually isn't that bad on the consoles for a FPS, it's very COD like but games can be a little slow because you can cloak etc. I play multiplayer mostly, only played about an hour or so in campaign. I suck though at multiplayer KDR is something like 0.75 but still fun nonetheless.
Edited by Dani Boi
https://www.sau.com.au/forums/topic/356321-crysis-2/#findComment-5747837
Got this yesterday, I have an E6750 Core 2 Duo@3ghz, and AMD 6970, gotta say, this thing is buttery smooth on hardcore, I think it even runs better than Crysis 1!!!
SP is pretty lame for the first hour or so but it gets way better :)
You can really tell that it's an console port though, when you first start it up it asks you to 'adjust the brightness on your TV', plus there are literally no adjustable settings for graphics other than normal, gamer, hardcore etc. You can I've heard adjust these things through screwing around with the console/config files I've heard though.
https://www.sau.com.au/forums/topic/356321-crysis-2/#findComment-5751689
^^ yeah im wondering how much better a 6870 1gb would be over 2x 4850 1gb = 2gb of texture memory
CPU is a Q6600 2.4ghz @ 3.3ghz
Dont forget that Crysis 2 is a DX10 game, but I'm sure that 2x 4850 would be better
See here for some good comparisons too: Graphics Card Heirachy Chart
https://www.sau.com.au/forums/topic/356321-crysis-2/#findComment-5751908
    • I'll give it a go, it cannot hurt Although, every time I go to Bunnings for one thing, I end up with a trolley load of stuff In other stuff news, I can fit 6 x 15kg bags of Gypsum in the boot of the MX5, I could have put a few more in, but I was already pushing my comfort levels buy dropping 90kg into to boot....LOL
    • It seems to happen only when moving not stationary. It happens more frequently when reversing and turning steering wheel to the right. I MAY have found what the sound is and if it’s that I will feel so dumb since it did start happening around when I put 18” wheels. I attached the image of where there’s a scraping line to that plastic liner and the other side does not have that.
    • Is it a noise that if you turn the wheel, and hold it turned to the right, the screech continues? Or does it only occur while you're moving the steering wheel? Does it occur when stationary turning the steering wheel from centre to the right?
    • I want to also note I did lift the tire and checked for any play to see if it was a bad tie rod. It doesn't move at all.
    • Any insight will help find the issue. When I do a sharp turn to the right I hear a screeching sound coming from the front. It only happens turning Right and not Left. Steering fluid seems okay. Not sure what this part is(picture) but one side seemed "wetter" than the other. All bushing from a quick look did not seem damaged. I'll do a better look but wanted to ask here in case it helps me troubleshoot faster.
