Hey guys, new to the forum. Have found a couple things on their site im interested in but have since heard they arent around anymore and have ripped people off of late? is this true or have I been given incorrect information? I did a search on here and couldnt find anything but on another forum via google did read of one guy paying them a few grand for parts that never arrived only getting excuses of couriers losing his parts? thanks!
https://www.sau.com.au/forums/topic/356659-powerplay/
Jeremy,
Please read this thread in regards to posting information you've requested.
My linkhttp://www.skylinesaustralia.com/forums/topic/228238-read-this-whos-the-best-tunerworkshopresprayerdetaileretc/
To everyone else, please do not respond to this request in this forum thread. If you have anything you want to say to Jeremy use PM.
https://www.sau.com.au/forums/topic/356659-powerplay/#findComment-5705601
Jeremy,
Forgot colon in the link :)
https://www.sau.com.au/forums/topic/356659-powerplay/#findComment-5705647
Jeremy,
Apologies, if anyone has any opinions/information please PM me, thank you
https://www.sau.com.au/forums/topic/356659-powerplay/#findComment-5705878
I used to use Powerplay all the time when I had my Skylines, I can't say enough good things about them. They have always done right by me and their work has always been fantastic! Yes, they are a little pricey but at the end of the day you pay for what you get and I'd rather spend a little more to have quality work.
https://www.sau.com.au/forums/topic/356659-powerplay/#findComment-5707244
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
    • We want to see pictures of the carnage!
    • The picture of the underside of that PCB shows either old flux that wasn't cleaned properly or some other contaminant (I.E Water). I would flush it with ISO and try again.
    • @silviaz Are you skim coating the entire panel (covering the entire panel with filler) before your hitting it with the long block? Or are you selectively applying filler to the repair, trying to fill the low points?  Please don't do that.  Almost certainly. Are you checking the panel for flatness as you go? Or is it more a case of, sand til all the guide coat is gone then check?
