ive got
hsd fully adjustable coilovers
work 17x8 with bridgestone potanza re01r 235/45/17 front and
17x9 with nexen roadstone 255/40zr/17
cheap rears but they wont last long anyway
305hp atw now on 14psi
chasing 300kw atw
Edited by hooray
Well take about 6% off your power everywhere because they added SAE correction (which ALLSTAR don't usually apply to RWD cars but I'll assume they did it on your graph because you asked for 400hp)... So that's about 380rwhp, then from a hub dyno you loose around 7% on top of that to a roller dyno dynamics so you are down to 355rwhp. So the same power as say a HKS GTRS on the same boost!
Next we will talk about boost response, well it's not really that bad considering the size of the wheels of the turbo (the 0.63 rear housing is helping a lot it seems). About the same as a T67 or a GT3076R 0.82 rear, mind they make about 430rwhp on the same dyno without correction on so the same response as yours but around 50hp more top end!
If you want to compare with my setup I make pretty much exactly the same power till 4000rpm and then a extra 150hp top end (mind you I cheat a little) :)
So in essence you have a turbo that makes the same power as a HKS GTRS with over 1000rpm less response or a turbo that has the same response as a GT3076R but with 50hp less top end...
CRAP!
I agree with what u have said but my safe tune is 18psi for a turbo that should be running 20 to 26 psi. I chose a .63 as I been in .82 and was a touch laggy for my liking. In future I will change to a .82 with more boost and aim for big hp.
fair enough but ideally you should be running a smaller gt30 with a larger (1.06) rear housing to get the same sort of power with better response and less stress on the engine (those .63 housings arent great for cylinder scavenging and temps). it'd also come on boost much smoother than the .63 gt35, making it much easier to control wheelspin.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
