quick question i know its prob been coverd many times but my comp seems to freeze every time i use the serach function (crap computer) im looking at running a atr43g3 and aiming for 270-300rwkw will my stock crossover pipe do the job or would i be better off making a 3" crossover pipe
https://www.sau.com.au/forums/topic/356787-crossover-pipe/
honestly calaisturbo.com will get you further, but no, you will need an intercooler for almost anything over 9psi with the stock turbo and perhaps 12 psi with aftermarket turbo, dont muck about without one, intercoolers are cheap as chips these days. your loking to run a larger crossover pipe??? methanol, lol
https://www.sau.com.au/forums/topic/356787-crossover-pipe/#findComment-5707471
[quote name=ClutchBurndout-:(' timestamp='1299721154' post='5707461]
there would be no point upgrading the crossover pipe unless you were upgrading the throttle body to
^^ this.
No point in upgrading any of the cold side piping unlesss going to a bigger throttlebody.
https://www.sau.com.au/forums/topic/356787-crossover-pipe/#findComment-5707478
i think really, the point is, throw away the crossover, because you will need an intercooler to make close to 300rwkw in a vl :thumbsup:, for the sau guys that may not know, crosover pipe means no intercooler......
In the skyline world a "crossover pipe" refers to the pipe that crosses over the engine to go to the standard clamshell intake manifolds on RB20/25's. Also sometimes referred to as a J-pipe (due to its' shape).
https://www.sau.com.au/forums/topic/356787-crossover-pipe/#findComment-5708164
I'm afraid that's wrong brah
https://www.sau.com.au/forums/topic/356787-crossover-pipe/#findComment-5708328
on standard VLs the xover pipe acts as a homo intercooler, it has heatsoak fins on it and shit
https://www.sau.com.au/forums/topic/356787-crossover-pipe/#findComment-5708590
yea, sorry i was assuming you ran a sohc rb30 turbo, which, as mentioned has some "cooling" fins as an "intercooler", but basically its a piece of pipe from the turbo to the throttlebody without an intercooler.
As you have a rb25, continue on, clearly i was on a different page :thumbsup:
https://www.sau.com.au/forums/topic/356787-crossover-pipe/#findComment-5710081
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
