Step 1
Purchase wheel stud from any autoparts store..
Step 2
This is for the rear wheel, for this the car will need to be in neutral with the handbrake off so make sure its not going to roll away by chocking up wheels then jack up rear of car and put on jackstands.
Step 3
Remove wheel
Step 4
Remove caliper by undoing these 2 bolts
Step 5
Remove disc, if it doesn't come off easily find 2 bolts that fit into the holes here, then turn them until the disc pops out
Step 6
If you line the stud up with this gap then give it a good whack or 2 with a hammer it will pop out.
Step 7
Put new stud in, bit tricky but can be done
Step 8
Now you have to pull the stud through, its a tight fit, to do this I put a large nut behind the regular nut. Then tighten it until the stud pops into place
Step 9
Then put it back together, give caliper a clean with brakleen or some degreaser, put a quick coat of paint on the disc and its good as new
Step 10
Replace shiny wheel after a solid hour of polishing >_<
https://www.sau.com.au/forums/topic/357402-replace-broken-wheel-stud/
Thanks alot man!
I'm deff going to try this one out.
But quick question, is it possible to pull the new stud all the way out when your pulling it through the hole? Or is there something to stop you pulling it all the way out? like a grove or a stop on the end of the stud your putting in.
Thanks alot man!
Yeah it will stop it has a flat end on it..
Awesome tutorial I thought I had to replace the entire hub but this is much easier and cheaper cheers.
When I pulled it apart I was thinking I may have to take the hub off too
Actually if you look in one of the pics i had taken the hubnut cap off, i went looking for a giant socket to fit but couldnt find one :D
  • 2 months later...
  • 3 months later...
  • 6 months later...
  • 3 weeks later...
How tight should the new stud be going in????
Mine was so tight i ended up stripping thread (while using the nut to pull it through) luckily i purchased an extra, so i went onto a different hole (i have 3 to replace) but that was the same so i stopped before i ruined that one too!
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
