Hi all I am running another group buy for AM Performance Blast pipes. I ran one about 8 months ago with great success and everyone was thrilled with their pipes.
The pipes are high quality stainless steel items in either 3 or 4 inch entry with twin 3 or 4 inch muffled or un muffled pipes so the choice is yours to option them the way you want. I high recommend the twin 4 inch muffled with single 3 inch entry for most cars as they look and sound stunning. All pipes are Tig welded and polished mirror finished.
hangers are not supplied.. its up to you to work out positioning and get them fitted professionally. if your in SA they can be fitted by AM Performance for a very small fee.
I will be doing a small run for now of 5 orders. I will neeed all 5 spots filled before placing an order.
Pricing works like this
$280 for straight thro pipes in either 3 or 4 inch.
$310 for muffled pipes in either 3/4 inch.
$30 for express postage on all pipes (if outside of SA)
rrp is $380 normally. so quite a saving.
all you need to do to place an order is to email me on MY EMAIL with your choice of diameter entry AND exit. make a payment to the acct below and once all spots are filled allowed 7 working days from then and they will all be done.
Simon Michelmore
Commonwealth Bank
bsb: 065-137
acc: 1076 8747
again... make sure you email me with an order. any questions feel free to PM me.
PICS
fantastic quality people!
i run a set of these on my s14, look great and sound great, very high quality items, you wont be disappointed.
Vu: best to speak to andrew directly and discuss what you want to do and he'll be able to give you a price. let him know your interested in a blast pipe from the group buy and you'll get a special price.
keen as!!
how much difference would there be between muffled and non muffled? (4" body 3" inlet)
a fair bit in terms of sound... the unmuffled are best for track only cars.
they visually look the same from the outside.
  • 3 weeks later...
this GB has closed.. those that have placed an order will get theirs hopefully by the end of the week or early next week (it is easter remember and this slows down postage times)
for those who are curious.. AM Performance are now doing titanium blast pipes :D can do a whole Ti exhaust if you wanted to but needs to be made to order (IE you'd need to be in SA)
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
