Have you thought about Soda Blasting? I've had the paint blasted off some plastic grill parts and it looks great. I've seen it strip the ink off a coke can and the can was fine. I'll post some photos when I get home later to show you the results. I'll also find the name of the bloke that did it for me.
https://www.sau.com.au/forums/topic/357458-acid-bathing/#findComment-5714641
cheers , yes I was considering soda blasting there's a guy in carrum downs does it..
But I ended up going to paint mobile in dandy , he recomended some industrial paint stripper and it worked a treat..
I guess the stripper I was using just wasn't toxic enough to strip powdercoat :)
https://www.sau.com.au/forums/topic/357458-acid-bathing/#findComment-5714729
There's paint stripper and there's paint stripper. The former being a clear, glue looking stuff that seems to just fade paint after half an hour. The latter closely resembling lava in both appearance and touch that seems to make shit bubble and peel after 5 minutes. Thick gloves = necessity lol.
https://www.sau.com.au/forums/topic/357458-acid-bathing/#findComment-5716239
yeah thats the stuff, thick brown goo the can sizzles when u shake it..
I tried 3m spray stripper. 20$ for 2 cans did nothing
some green stuff from bunnings 40$ a litre was a little better but still no good.
25$ for half a litre of the good stuff from paint supplies store, i used half a tin and job done.
https://www.sau.com.au/forums/topic/357458-acid-bathing/#findComment-5717705
Yeah, you paint the stuff on with a paintbrush :)
You had any splash on your skin? Instant BURN.
The one the smells like ammonia?
We used to put a drop on our palms and see who could hold it out the longest...
but i've always thought they wouldn't work on powdercoating because its like baked on plastic.
https://www.sau.com.au/forums/topic/357458-acid-bathing/#findComment-5719110
No, the one that you smell and it burns your nose just because of the fumes lol. There's no way you could put this one on your palm and see who can hold it there the longest - it starts burning instantly and leaves something of a nasty chemical burn after 5-10 seconds.
https://www.sau.com.au/forums/topic/357458-acid-bathing/#findComment-5719487
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
    • Makes sense. For actuators, if the pressure itself isn't adjustable, that would mean I'd need to think about 2 different actuators with 2 different pressures on paper in order for them to work at the same time if the turbos behave differently. So measure the difference in psi needed to move both, and then get an actuator to match that difference. Assuming I cant get rid of it by adjusting the arms.  You're exactly right, never happens in gear 1 or 2. I can occasionally get it in gear 3 if going uphill but its very small. Only ever in 4 and 5. Seems kind of backwards that one of the points of VCAM is faster spool but if it introduces shuffle then it actually slows spool down.
