well our skyline should be rego'd on friday woot
started it on the weekend and it made the rattle sound at the front near the timimg belt cover area so i am guessing its in need of a belt/ tensioner/ bearing change from all the youtube and forum reading ive done????
Is it only on startup or does it persist?
yours is going on the road mines getting taken of the road in a couple of weeks for the big 30/26 f#@k YEAH!!
That should make some serious power.
I'm in Kallangur
Car - R34 GTR Midnight Purple III
Plates - HLUCN8
Soon to be rocking ALOT of carbon fibre parts...
i saw you on gympie road get a love tap on the ass from another car the other week. a glancing blow?? car looked mint!
oh yeah narangba too
4dr r33 - not too much done to it (being a "family" type care, trying to keep mods to a reasonable level hehe)
Haha true
Mine came a tt but Ive never used it, and a varex muffler, but the remote doesn't work( haven't got round to figuring out how to hard wire it to a switch in the dash
I've only done a front mount on mine, tinted the windows and put slotted rotors on
That's as far as my mods will prob go.......
For now haha
Edited by BstewyR33
off to BJJ training down at Red Dragon at caboolture,
our skyline is registered now YAY
just need to get some spacers so we dont bent the front number plate and throw them on
1 year in June
I only do BJJ none of the other stuff,
the cage fitness thing is real good for fitness and the guys who do the MMA class enjoy it ,
they always win stacks of trophys in the Wing Chun and Jow Ga stuff at comps
Ah cool, I trained with them for about 4 years (along time ago)
Back when they were in burpengary, then the first shed in morayfield, then faded out & lost interest
Was only wing chun and jow ga back then
hey Noy I see you fairly often on the gateway,
I get on at Nudgee in the afternoon
once my bodykit goes on the cressida you will probably notice it more lol
I'm usually in my own world, enjoying my slow drive home.
What colour is your cressida? what kit are you getting?
Love tap for sure, what do you expect from dozey commodore drivers.
Shannons have come and inspected it and Exclusive Auto Centre are repainting a new rear bar,
also needs exhaust fixed, new number plate. Glad i didn't have all my carbon stuff on.
my Cressida is silver with twin 3" exhaust out the back (drift style i suppose)
and a big front mount and 17" mx5 alloy wheels(quite spokey)
The BJJ class is good, its no black belt level BJJ class but its better than driving to Kelvin Grove every day as thats the closest black belt run school:(
Any know someone with a dark blue 33 NA. it was trying to do a burnout in front of IGA on glenwood drive on saturday. I felt kinda bad for him and ashamed that it had a skyline badge on it when it should bare a pintara badge.
Edited by RandomHero83
another cabbo here, born and bred......but avoided :P
plain white R33 GTST. stock wheels and all :) got some GTR wheels to go on it once i run the original tyres into the ground.
owned the car for just over a yr. done 40 tho and no issues yet :) other than fuel prices.
my little bro has an R32 GTST, mags exhaust and stereo.
so a meeting of some sorts sounds in order??
Edited by boiracer
i think ive seen this car too.....no idea who it is tho.
a weeknight meeting would be best i think. due too most people having other engagements over the weekends. ( i know i do).
i just dont know of a suitable venue.
The new 7eleven servo / Big dads pies / carwash on Bribie island road looks like a good place to me.......but its not even finished yet...let alone open. but def could be a future possibility.
any ideas?
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
