Hey guys. Live in D'bay, the better side lol. I'm opening up an Auto elec shop in Morayfield next door to my tuner, so you'll probably see either of my cars floating around.
Mine: White R32 4 door
Plates: 116 HKS
Has 317rwk
Daily: White N13 Pulsar.
Plates 811 IDV
Wifes: Marine Blue R33 4 door
Plates: 583 JJQ
Standard with the usual mods.
Nice!
Could be an opportunity for a meet point when you open the shop?? Then the cops won't hassle us as it's your business???
Is it next to RPM up near yamaha or ??
It's on Dickson Road. About 100-200m up the road from the north entrance of the shopping centre, in the Pitstop complex. Peter (RPM) has given me the opportunity to run my own shop under the RPM banner. As for the meeting spot at the shop I think it's all getting fenced off, as we want as much protection as possible for both our sheds. Once everything is up and running we're looking at having a dyno day. If ya around the area when it's open pop in and say hello.
Hey guys, living in Caboolture.
got a 2003 V35 coupe, pretty standard.
2006 bi-xenon headlights
Factory LSD
Alpine headunit and speakers
Koya 19x9.5 +15 wheels
MCA suspension
Infinity badging
Can't wait to start spending some money on it.
i live in morayfield also, have a unique colour green(looks better in real life) r33 gtst.
Currently building an rb30det for it
has a gt3082,44mm tial gate, high mount manifold, greddy copy intake, 660cc injectors, haltech e11v2, large front mount, water meth injection
But lucky me getting to drive my missus fwd diahatsu applause with about 30hp
Ok we have plenty enough people to organise a get together even if it's only to shoot the shit and dream about what we want to achieve with our toy's anyone got an Idea for a meet Location and a night / time.
My opinion would be wait til the easter break is over and the cops lay a little lower. I have heard the cops are doing a blitz this weekend and up til easter on common spots. I'm not sure if some of you guys have heard of Club Highrollers at all, but i'm a club member on there. We are based mainly from sunny coast to the gold coast, but have had a few members join as far as tassie. We are having a drag day out at Willowbank, plastic vs muscle battle. The spots have been filled unfortunatly, but could be a good day to come and watch. Use the link provided, clubhighrollers, join up and let the good times roll. We have new management now and have a few events and monthly cruises to attend. Be good to see some of you join.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
