sorry, i didn't recognise you, i had a little on my mind at the time
Was it the stray cat?
Bodo I am going to need to borrow your expertise in cleaning my car as she is in a desperate state atm. I need to learn how to do a proper detail job so I will put some beers on if you feel like doing some schooling.
yeah man, that could work, just gotta come up with a time that is good for both. i'll be busy both the next 2 weekends with the Dyno day next saturday and QR happylaps the sunday after.
might do a beer and BBQ at mine on a coming thursday instead of heading out if anyones keen? i have room for sitting drinking and car tinkering, both inside and outside :)
that's pretty keen man.
I am starting to get Ill so I will be staying home till this shit passes.
Home loan is approved we start building in july should be ready by my birthday.
Just wait till u speak to them xD I'll be spewing if mine takes longer then yours!! Baby needs a house :( although the chance to save my for would be nice.
I'm keen bodo, not as keen as joe tho. Mustards bleh!!
I'm on fortnight mornings so I'll try and make the meets! Like the idea of beer tho. Mmmm.
Contemplating doing the detail now as well, so when u both decide to do etc lemme know and I'll come for it
Car: 1993 r33 skyline gtst
Colour: black with carbon bonnet
Mods:Engine: rb25det
gt35/40 turbo
6 boost manifold
4" dump to 3.5" exhaust
custom cooler piping
50mm turbosmart external gate
microtech lt12
yellow jacket coil packs
walboro 285lph pump
hd excedy clutch
660cc injectors
greedy boost control and turbo timer
custom plenum
turbosmart bov
sard fpr
oil catch can
Exhaust: hks
Suspension: hks coilovers
Wheels: 18" drifttek
Modifications: g
tr front bar, 400r skirts, gtr pods,gtr wing
carbon wing blade
carbon vented bonnet
carbon scuff pads
carbon dash surrounds
carbon coilpack cover
slotted rotors
harnesses
led taillights
gtr grill
tint 18%
gtr seats
brown davies half cage with intrusion bars
momo wheel and pedals
el gauges
bride race seats and harnesses
Stereo Audio / Visual: jvc tv/dvd, alpine front splits kenwood rear 6x9s running off a sony amp, single 12" sub running off fusion amp
Estimated Power: 420.5rwhp 314rwkw
Plans for the next Mods: forged motor
Owned for: 10 months
live in morayfield
anyone know of meets on or cruises or want to meet up and make a cruise up message me
Edited by whitr32
yeah man, in this thread. normally thursday night. either up here or in carseldine......we've been a bit slack this year so far :P
and the occasional drive to see the westies, depending on how many show up and are keen
car sounds nice man :woot:
Yea there's a few of us, lazy bunch though :P some of us socialize out of the meets tho which we need to do more of. Speaking of which, bodo if u and ur misses are keen I have an inv to my engadgement party on the 26th I think it is. I gotta let Clint no aswell
I will gladly come along, but Maureen has a hen's night to attend that day, so she will not be able to join us :(
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
