Hey bodo, when ever ya free dude I got that knobby. Just waiting for the major modification! Lemme know!
Oh got the reservoir too. Thanks jdmspares for sending me a dirty and gunk reservoir tank. Beer buying from u again.....
Sorry been real busy...and totally buggered. didnt reply to your message either :(
should be right to do it some time this week, as for the lights. cant remember exactly which ones they are. ill find the packaging and let you know.
Just got back from getting the wifes Beetle tinted. looks good. :woot:
No worries dude, I'm on arvos this week so maybe catchup on the weekend. I've got a cold ATM so don't wanna give it to anyone else.
My sticker mistake has been fixed thanks to Troy, cuttin is back and doing one more cost and wallah. She's new!
Got my car back yesterday... Crank Angle Sensor was rooted as well so got it upgraded and new tune. Dyno attached
Mods are
R33 GTST S2
Stock motor
FMIC
Spitfires
Nismo 740cc
Walbro fuel pump
Vipec ECU
GT3076 [Low mounted & Internally Gated]
3" Exhaust with Hi-Flow Cat
4" Intake pipe
Still seems a low figure. Do you guys agree?
Edited by SCR48
That looks ok IMO, how much boost are you running? May not b a huge thing but if u dif the pump did u do the regulator aswell? I know Clint did both and he runs close beside a high flow.
Still a big improvement though!
I was going to go with a highmount setup, but the costs and cons of doing it isnt worth the money nor the power you make, which isnt a hell of a lot.
There are so many more options to go than that, but thats just me :P i would probably look at going forged if you want a beastly power with the 25, now thats worth some dosh :D
Bodo, lemme know if your free sometime before sunday this weekend? ill bug ya for the gear knob, otherwise tee it up for next weekend
Running 18psi.... Think I'll look into upgrading exhaust to 3.5" and save for highmount setup
Lot more money and not better result. is that 3076 in a .82 internally gated rear housing?
Having said that its an out come of a package instead of a turbocharger alone. As a bolton option it isn't unreasonable, and rarely any one makes their desired output in the first go. Either way, the most your are likely to see on paper with current setup is roughly 280rwkws. For trouble shooting I would drop the exhaust, try a different pod filter, and a different cooler. Some of the small alterations do make a big gain.
Ultimately a proper high mount manifold and external gate definitly helps with top end power.
Sometimes northing ever goes right does it!... driving car around last day or so and seems once i get a little happy with the right foot it starts making a strange sound in boost over 4000rpm and engine light flicks on and off.... Looks like it back to the workshop it goes on Monday. Hopefully all will be fixed for powercruise on Thursday
its likely to be an occurance of high level knock. engine light doesnt come up unless knock level goes beyound 60 means danger. the sound you heard is probably detonation. i would take it straight back to the tuner for a check up.
does the engine light blink on then off?
Yep, exactly what it does.
its likely to be an occurance of high level knock. engine light does come up unless knock level goes beyound 60 means danger. the sound you heard is probably detonation. i would take it straight back to the tuner for a check up.
already booked in monday. hopefully it gets fixed
Welcome to the world of detonation unfortunately. Not bad power for the mods. If you do little changes, such as a larger exhaust or a different pod filter, it can alter the tune a little. A lot of people don't realise this. There would be nothing wrong with the size of the exhaust, there are plenty of cars producing big hp on 3" systems, so I wouldn't be worried about that. If you want to change pods, i'd do it now before it goes back, or give them it so they can fit it before they retune it.
It's got a new pod in the last few weeks, they just upgraded the CAS the other day and retuned it.... Maybe it's related to that...There's a thread in forced induction where someone is experiencing knock and believes its CAS related
Edited by SCR48
+1 to the exhaust. To many people think the exhaust is the answer when it isnt
Don't mind me just lurking around, I'm a North Sider not rocking a beasty Skyline yet.... but hopefully real soon just wanted to have a look and see what we got on the North Side :D
Edited by NFORSA
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
