If I only had to do one lap it wouldn't be a race... (Problem is after 3-4 my brakes go bye bye)
If you didn't skimp out on the more important things of a car this wouldn't be an issue. Even I know the importance of brakes hence brakes before any powet upgrade ;)
NO! Many other cool bright colours to choose from for a cool urban camo. Pink just isn't that original.
What are you proposing Bodo, I am looking for Ideas so fire away man.
I persoanlly think pink camo is just gonna be slapping a pull me over sticker on the car. If it were just race car I'd so go for all the awesome.
I don't know about that, A few mates have over the top paint jobs and they have never been pulled over other than to have the copper look at it and tell them it's a nice car. I just want a paint job that really makes the car pop.
My colour scheme is fairly obnoxious and I got hassled accordingly... It's not a good feeling knowing a coppa is staring at you as you drive by
Pink Flaming Galah camo?
  • Like 1
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
