lol.....so Im hung over and a bit woozy from last nights Origin Annihilation, and my bonnet is probably getting wrapped late this arvo.
I may not be able to make it tonight :( will let yas know.
I can come pick you up. Not many other people that I know going.
Indeedy.... he's been targetting me lately, apparently there is something wrong with me.....or im just getting old.
You could be getting old, but then again your old so you'll blend right in
