Bodo lacks the Powa, but has the styles....
There is so much stuff id like to get blacked out on my car. most of you have probably seen 34GeeTeeTee's build thread. His engine bay backed out is puuuurrrrfect
Pish posh, needs more chrome and Fluro :banana:
Join us? I think theyre going to be taking money at the door $50. and from what I know plenty of room still
Yea wish i could lol, cant really afford that atm, tight budget, even my budget has a budget!
The gear knob is alot better than that other piece of shit lol.
How ya been anyway?
Yeah good man, also married (on a budget). And only a few months away from a late Euro honeymoon! Im going to be sooo drunk on cheap awesome boozes.
I was going to cut that (gear) knob down for you so that it fits properly as I recall. No issues with the tiny little adapter for the thread?
Haha yea, we get married end of august
. Honeymoon sometime down the line.
Yea it sits ok.. just want it to sit a bit lower than it is, still a tad high. Threads awesome, has never come loose.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
