Yeah got it sorted thursday, bring on the events and new coil packs it seems.
Yeah took the bikes up to glasshouse on sat for a blast. A great day out till a mate hit a tree lol. We called it quits after that. I need to get a trailer bad, lifting the bikes up on the back is a btch.
And yeah it's good to be back, I'll be getting around in the line on the weekends pretty much, and events of couse.
Any of you guys going to kawana meet on sat night?
