The gastro bug that has been doing the rounds, It's never fun. Just glad I have not caught it (touch non sexual wood)
Go to Bunnings.
Buy Bleach
Buy very strong multipurpose cleaner
Clean EVERYTHING
On hard surfaces, this bug can live for up to 12 days. It's a shit thing.. hehe.. pun :P
Start wiping down every surface and don't touch things unnecessarily.
Be careful to clint, received a letter from aus christian college saying there are several cases of scarlet fever going around to. Fever and rough rashes are the signs, 3 days isolation is the treatment to.
Looking forward to sat night, heading to hoppys to get prepped sat morning, better not rain lol.
Anyone know where you can get aftermarket coil packs over the counter in bris?
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
