Unlikely mate.
Waa!
bad backs are a curse to live with. Are you coming to Oktoberfest?
Bad backs are shithouse, first farked mine when I was 11 and got thrown off a horse onto the crossbar of the jump, fked it numerous since and live on anti inflams and pain meds then so hopefully yours isn't too bad!
Waa!
It's must muscular in my lower back, hopefully it goes away in a few days.
Connie needs to give you massages... But no happy endings, you is broken lol
Mike, if you come to Oktoberfest, I'll also buy you a beer. :)
So will I - That is 3!!! DO IT!!! COME!!!
She did...even threw in the happy ending :yes:
Back is still stiff and sore though.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
