To be honest I don't care about your opinion of me, I don't see you coming to meetings that affect the club and voice you opinion just a bunch of key board warriors.
Apparently.... In other news. Hopefully ill hear back about the motor vehicle this week... If so I might pop down there with Clint to sus it out
This is a sound Plan.
+1 to this.
This place used to be about driving many years ago. Now its about politics and polishing the execs knobs.
Shit, the current execs weren't even in the community back when I remember it was thriving. Do the current exec board even drive skylines? You know, real ones that is.
Agreed.
I think it's more a case of the Execs polishing the knobs of the traffic squad though.
There are a whole lot of automotive uncle Tom's going around.
Question is, what are you going to do about it?
Can't just censor dissent on here :thumbsup:
Lol, i dont know any of you nor care, when i was actually active there was none of this ballshit going on.
Settle down and enjoy the forums, dont ruin it and push people away.
On a side note, anyone keen for a meet n escort next friday? Im doing my sister in laws formal then going to woodford pub for a beer.. or 5
What's the travel plans (start location and time etc)?
Can i get back to you so i know 100%?
So far i know it starts at morayfield high, drive to woodford somewhere (just outside i think) and then i was just gonna go to the pub for a few. Ill get times etc, if anyones keen ill organize it
If I have enough fuel and don't have anything on I'm keen.
Alright sweet, ill put on a jug of nice cold beer, will let yas know what the go will be if any decide to come.
So whats the facebook thread? If its more active ill take a look
just got myself an npc twin plate clutch, good for 1000hp at the wheels ;) just incase i make more than 700 :)
Nice!
SAUQLD?
About time. Were the winds blowing in the wrong direction? Slowed down your pace did it?
Yeah...if by wind you mean boxes and boxes of Connie's stuff filling the living room.
  • Like 1
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
