Hey there I was wondering if anyone could help me out with the dilemma I'm faced with. I have a low r33 gtst and love the "flush" look I currently have. With lowering my car substantially I have also noticed that my steering has gone downhill. My questions are:
1. I have seen people use solid subframe risers like the ones from MAX, are these a good solution or just a band-aid fix?
2. What is needed to fix the front suspension geometry?
3. Should I just raise my car?
Thanks in advance.
You're going to need to explain it better, "my steering has gone down hill" says literally nothing about the problem you're having.
Do you mean your car still rolls?
Back kicks out more?
Doesn't steer straight?
Scrubbing?
Gonna have to be more specific mate...
My question is really aimed towards fixing suspension geometry by raising both the rear sub frame and front LCA. I believe this is the root of the problem.
Edited by Luke_GTS-T
well you have front camber goin on, overly lowered cars generally wont handle as well as properly lowered cars that have been aligned well..
so have you got:
adjustable camber bushes front and rear
adjustable castor (not a necessity but can help)
Im guessin if you dial out some of the camber your wheels will scrub, so raise the car and get a correct alignment... or better offset rims thinner rims (so you can fit them under the guard once you lower it that far) and lower it again... but lack of tyre width will reduce grip a tad.
  • 3 weeks later...
Hey thanks Brentton, although I'm in NSW.
For the people that are suggesting wheel alignments and the like.. I really don't think you've caught onto what I'm talking about.
What I'm talking about is along the lines of re-drilling the lower control arm / castor arm up higher to correct geometry.
If anyone has done this to their car please shed some insight onto what exactly is needed to do.
Another place I’ve heard of that is highly recommended is Hassam (I think that the way its spelt) and im pretty shore they are in syd.
Ask in the NSW section for a recommended suspension specialist.
Its Heasman, they're awesome
the car feels less responsive and generally feels less direct when being pushed.
This has a lot to do with alignment, lowering your car will put alignment out of spec, (more -ve camber, excessive toe in) get an alignment done and go from there
if you want to change the position of your lower control arm to correct roll centre, you can do this with adjustable urethane bushes, but you can only raise it so much
you're still better off raising the car to the right ride height for this
You have rooted the geometry of the chassis by excessive lowering.
You can fart arse around trying to correct roll center, bump steer etc etc but it will never be right without re designing the geometry and fabricating new pick up points and arms.
NO alignment or bush changes are going to correct the issues you have created. I specialize in suspension geometry design and correction for circuit racing, it is possible but costly to rectify properly.
Keep in mind if you wanna fix the geometry you're probably going to have to modify the upper arm as well...
I know nisskid was toying with the idea of putting basically an S14 front setup in his R32... not sure how far he researched into that though.
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
