Hi all! Name is Viet, just got an m35 stagea 2weeks ago but its got some minor problems.
My faint engine light keeps appearing even after ressetting the ecu, it comes up with code 0171 which i believe is left bank lean. I notice that my car drinks alot (18l/100km) so im suspecting the o2 sensor which from nissan is $160 with a 2 week wait.
Also notice that on my stock exhaust only the left tip is working, the right is clean.
Does anyone know if the skyline v35 o2 sensor can be used and also if the v35 nav unit will work in my stagea as it was missing from purchased?
Having a hard time of finding basic servicing information as in:
Oil used, how many litres to fill up?
Oil filter part number?
Spark plug number and gapping?
Transmission fluid and capacity?
Diff fluid and capacity?
Also would the arx shocks and springs fit my stagea? Ive got rsr springs atm and i go fishing alot so doesnt clear the dirt roads.
Thanks you advance!
If anyone lives in the western surburbs of melbounre and would like meet up please pm me, would love to learn more about these cars!
4wd fluid and capacity how to bleed?
https://www.sau.com.au/forums/topic/357701-m35-stagea/
OK, I'll bite. Can't give all the answers but some of them.
Don't worry, it opens up when you give it a boot full. the exhaust is variable and contains a pressure flap inside.
1) don't know 2)the Nav function will never work as its Jap only. Buy a UBD. it would be a lot of work to get the shit in there.
4.8 or something like that - most of us are lazy and just dump a 5 litre bottle in.
I can't be assed going downstairs and looking - just ask for something from a 03 350Z you'll get the right one. its fits a shitload of nissan cars.
Different people have had different experiences. Have a search on the site.
Nissan Matic J, or Nulon 100% sythn seems to be the other proven performer. about 8.5 litres - remember you have to flush it not just drop the Pan, that'll only get about 4 litres.
Redline shockproof - about 1 L per diff I think. Use good quality cause you don't want to change it for a long time...
Don't know. should have bought an ARX....:thumbsup: Might be the worlds only Raised Stagea!
Nissan Matic D / ????
Hope that helps you to some extent.
I'll let the other guys handle the error message- I have my own thoughts but they are more experienced.
https://www.sau.com.au/forums/topic/357701-m35-stagea/#findComment-5717272
The ARX springs will get you a little more lift, I didnt swap my shocks over but I've got ARX springs in; with Nismo springs my front lip was 8cm off the ground.. Looked AWESOME but killed me in terms of functionality. Im now somewhere around 15cm off the ground at the front. So if you need some height and can source the springs, do it thumbsup.gif
https://www.sau.com.au/forums/topic/357701-m35-stagea/#findComment-5717312
I've got a set of factory ARX springs and shocks in storage if you must go higher. But I recommend lowering of the RS/RX for bitumen and finding a ute for fishing.
I know what you mean about the exhaust tips. I didn't realise until now that the Calsonic has a pressure flap - clever. I just thought mine was always blocked .pinch.gif
Agree with everything PN-Mad mentioned. I replaced my transfer case and Attesa fluids and there is lots of good info on how to do it with the search. Both fairly easy but I needed an extra hand with bleeding the Attesa pump.:thumbsup:
https://www.sau.com.au/forums/topic/357701-m35-stagea/#findComment-5718317
Hey Gazza,
Did you replace your ARX suspension with BC's ?
How is the ride now?
https://www.sau.com.au/forums/topic/357701-m35-stagea/#findComment-5718423
Hey Gazza,
Replaced the shocks with Bilsteins and the springs with original-height (ARX) King Springs heavy duty. However, I've recently seen a heap of lowered ARX and they do look better - even with the flared guards. I just find the tailgate doesn't open high enough so at the time decided against lowering.
The ride is firmer but still comfortable. It just suffers now from the factory sway bars but Dale will soon sort this out with the Whitelines.
https://www.sau.com.au/forums/topic/357701-m35-stagea/#findComment-5720916
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
